Originally Posted by hell_storm2006
I cant even see the BIOS Screen. Its not booting. Anyways I found the problem. Its short circuiting! I have Zebronics cabby (I have no idea why i bought that.... absolutely sucks!!!!). Whenever I screw up the mobo the PC doesn't boot. I mean actually its coz the screws are so small I have to really put in a lot of force to make the mobo stay in its place! Any solution for this???? I fear that I may break the mobo someday trying to fit it in the cabby!!!
If can't afford a new cabby then try glue...quick fix or dendrite. Just be cautious dat they wont spill on circuit.
B/W u can sell ur cabby in and around 500-800/-
New good cabby may cost 1800/-2000/- (Nzxt, CoolerMaster)...
Put ur cabby on its side, like place d side where mobo is placed on ground, dat way ur mobo won't loosen up; u may have some problem wid CD/DVD
