Old 14-02-2009, 09:14 PM   #1 (permalink)
Unhappy Hardware Troubles
I just bought an Asus P5Q-e mobo....with 2X 2GB Corsair XMS2 2x4098-6400-C4DHX...with latency 4-4-4-12...however in the bios it shows the default timings as 5-5-5-18. Why is this?...I tried updating the Mobo firmware to no avail....i don't want to overclock the memory...why is the default timings wrong... any fix ...please reply urgently
Ultra_Bloodshed is offline
Old 18-02-2009, 07:22 PM   #2 (permalink)
Default Re: Hardware Troubles
hello... bump!!
Old 18-02-2009, 09:11 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
mobos some time could not detect latency correctly.
Just set the mem timings manually & your prob will be solved.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-02-2009, 12:57 AM   #4 (permalink)
The Sorcerer's Avatar
Update bios and put the timings manually. One of the "god knows why" issue on asus board. I wish I could say this was a chipset issue- but other p45 boards from different manufacturer had no issues like this
Hardware BBQ
The Sorcerer is online now
Old 19-02-2009, 03:08 PM   #5 (permalink)
I have updated the bios but the prob seems to persist!! My local technician has no clue and neither does the ASUS support center... Setting the timing manually, is it ok?
Old 19-02-2009, 07:45 PM   #6 (permalink)
Intel OCer
amitash's Avatar
^It happens.... set them manually nothing will happen...dont touch any voltage settings though
My site: collegeclassroom.org
amitash is offline
Old 19-02-2009, 09:38 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
There will be no prob & don't do anything with voltage options as amitash said
& don't change ram frequency too.
See your mobos manual for how to set timings.
Generic procedure : There should be a option like memory timing setting with optial default selected. Set it to expert & then you will be able to change timings.
topgear is offline
booting troubles with cd windchimes Software Q&A 6 11-02-2008 11:13 AM
WinXp sp2 troubles me dreamzchm Software Q&A 3 18-08-2007 12:37 PM
RAM troubles... raskal00 Hardware Q&A 10 18-02-2007 08:44 AM
ASP.Net troubles vuttu Software Q&A 5 16-07-2006 11:19 AM
DOS troubles deepakuma QnA (read only) 3 20-12-2004 12:21 AM
