Old 14-02-2009, 06:38 PM   #1 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Arrow [BUDGET] Suggest me a good Keyboard and Mouse combo
I want to keep this under 1000, and, if its available, I don't mind going for Rs. 500 wallahs.
I need a good keyboard and keys should be properly spaced. I am a touch typist and I can type with my eyes closed, so I need something upto my standards. I want soft keys because my syster gets angry on hearing typing noise. I intend to game.
For mouse, I preferably want Lazer mouse. Again, I need something sensitive.
Only branded stuff please. iBall sucks balls so please DONT recommend it.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 15-02-2009, 04:16 AM   #2 (permalink)
Machinehead..
fireshots's Avatar
Exclamation Re: [BUDGET] Suggest me a good Keyboard and Mouse combo
get the iBall business combo (red package)..it has a basic but a very sturdy keyboard n extremely lightweight optical mouse, it shud not cost you more thn 600/-. Its a value for money product.
I saw u hate iBall but this product will change your outlook towards iball.
fireshots is offline
Old 17-02-2009, 06:03 PM   #3 (permalink)
The Smaller Bang
Default Re: [BUDGET] Suggest me a good Keyboard and Mouse combo
I have this keyboard hence I am saying.
Trust me, iBall sucks.
Its keyboard develops a problem around 2 years after purhcase.
Randomly "+" button activates and my textboxes are filled with ++++++++++++++
Ask in #think-digit at chat.freenode.net IRC and you will know/
I was banned several times because of spamming with ++++++++++++++++++
Old 18-02-2009, 10:48 AM   #4 (permalink)
Point Blanc
microsoft 2000 keyboard, but then it itself is of around 1K,
i have microsoft mouse working good cost 450.
if strictly saying as per money logitech combo is very good. check the multimedia combo or internet combo ones.
acewin is offline
Old 18-02-2009, 01:45 PM   #5 (permalink)
The Smaller Bang
I remember Logitech Rs. 500 combo.
But I want Lazer mouse instead of Optical Mouse.
Old 18-02-2009, 01:52 PM   #6 (permalink)
Point Blanc
check lazer mouse from zebronics costs around 600, except I do not know how good they are compared to logitech
acewin is offline
Old 18-02-2009, 01:56 PM   #7 (permalink)
The Smaller Bang
How is sensitivity of Lazer mice compared to Optical mice ?
I play Counter Strike, Urban Terror, etc and similar FPS games needing good quality mice.
Old 18-02-2009, 02:37 PM   #8 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Logitech keyboard+mouse is the best,this mouse is good for online play.Also i hav Micrsoft kb+Mouse but not at all good for gaming.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 18-02-2009, 03:22 PM   #9 (permalink)
The Smaller Bang
++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++w+hi+ch model of mouse are you talking about ?
PS: see what I mean by iBall issue ++++++++++++++++++++++++?
Old 19-02-2009, 07:55 PM   #10 (permalink)
The Smaller Bang
bump...
btw, today the problem has temporarily disappeared.
Old 19-02-2009, 08:06 PM   #11 (permalink)
get anything logitech, mouse and keyboard combo should come under 650
Faun is online now
Old 19-02-2009, 08:06 PM   #12 (permalink)
Juke Box Hero
I never cared at all for keyboard and mouse, but FWIW I use a iBall Basic Keyboard and a Microsoft Optical Scroll Mouse.
Hitboxx is offline
Old 19-02-2009, 08:09 PM   #13 (permalink)
The Smaller Bang
Since how long do you use your iBall keyboard ? Mine and meeow's keyboards started goofing up after 3 years of usage.
I specifically need lazer mouse for gaming.
Last edited by MetalheadGautham; 19-02-2009 at 08:09 PM. Reason: Automerged Doublepost
Old 19-02-2009, 08:14 PM   #14 (permalink)
Juke Box Hero
IIRC it's been more than a year I think, I change key and mouse once in 2 years as a rule.
And lazer mouse? C'mon, I am a more hardcore gamer than you and I use what I use for day-to-day gaming.,as in., daily online pub. It is more than sufficient.
Personally I don't believe in fancy gaming hardware if you're not in it professionally and is just a waste of money.
Hitboxx is offline
Old 19-02-2009, 08:41 PM   #15 (permalink)
Point Blanc
@metalhead, I have not used lazer mouse so cannot say how good they are.
cheapest logitech lazer mouse is MX518 which costs around 1.2-1.3K
and a basic keyboard costs 300 bucks.
I also play CS, but never with a lzer mouse
cheapest lazer mouse you get would be iBall and Zebronics in 500-600
acewin is offline
Old 20-02-2009, 08:55 AM   #16 (permalink)
The Smaller Bang
Well, my iBall mouse has horrible response times.
In Urban Terror, I can notice a visible lag between the time I move the mouse to turn around and the moment when the mouse does turn around. This has most often been enough to get me fragged.
I was hoping that a good lazer mouse would propably solve my problem.
Lazer mice are not "fancy" gaming hardware. You are refering to freaky looking mice with lots of buttons reviewed in Digit which I couldn't possibly care less about.
Forget lazer mice for a second, but do optical mice from logitech have good response times ?
I realised that its not sensitivity but response times which my iBall mouse lacks while gaming.
I can buy any cheap optical scroll mouse as long as it does not pwn me with high response times.
And yeah, I saw Logitech Lazer combo at 1K in the latest prices thread.
Old 20-02-2009, 09:34 AM   #17 (permalink)
Bond, Desi Bond!
desiibond's Avatar
You really do need to try out lazer mouse for gaming. I am using one and every one of my friends who tried it accepting that it is exceptionally smooth and lot more precise.
@gautam, am pretty sure that you won't get quality laser mouse+k/b inside 1k.
If you want laser mouse, you need to increase your budget or just get Logitech combo.
desiibond is offline
Old 20-02-2009, 11:21 AM   #18 (permalink)
GOD
vaibhav_jain's Avatar
get yourself a logitech keyboard and mouse combo in around 700/= it is best and also its warranty is 3 years i recently purchase one. it is internet pro keyboard
Vaibhav Jain
vaibhav_jain is offline
Old 20-02-2009, 12:02 PM   #19 (permalink)
Point Blanc
logitech/microsoft mouse which I am using are quiet good not much noticeable lag can be said, beside there is a gaming combo which comes in 1.3K G1 gaming desktop, of which mouse is quiet good. Played CS quiet alot with the logitech one, hits being precise, when I turned around it did not deflect my face to corner me down not able to see my target.
My friends played with the same mouse with quiet ease on fast game like UT and other, I experienced iBall mouse only once one of my friend bought it because it was quiet fancy, but to got bad quiet quick
mouse in the G1 gamin set is much better than general logitech optical mouse
it being the best combo in the price
but do not think it is a lazer mouse
and if you are getting a logitec lazer combo in 1K and can get it, do not have second thoughts.
acewin is offline
Old 21-02-2009, 06:49 PM   #20 (permalink)
The Smaller Bang
Here comp@ddict says that his friend bough Logitech Lazer Combo for 1K.
http://www.thinkdigit.com/forum/show...14#post1055114
Old 22-02-2009, 04:06 AM   #21 (permalink)
Point Blanc
we can ask him to give the exact make and model, if its true you should not have second thoughts
acewin is offline
Old 22-02-2009, 12:56 PM   #22 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
It's the laser mouse worth rs.500 and standard kbd worth another 500.
But if you want the best, and cheapers a.k.a. VFM deal for gaming and other purposes, this is the best option:-
Microsoft Comfort Curve 2000 @ 1.2k
Logitech MX518 Laser @ 1.4k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 22-02-2009, 06:11 PM   #23 (permalink)
The Smaller Bang
Which laser mouse is worth Rs. 500 ???
And are Microsoft Comfort Curve 2000 and Logitech MX518 Laser simply keyboard and mouse and not combos ? If yes I am not intrested in spending 2.6K for keyboard/mouse.
Should I check out some of those weird egronomic wavy keyboards from MS/Logitech ? I am already used to typing in my current keyboard with my eyes closed but its the standard design. Will I have any difficulty migratng ?
Old 22-02-2009, 07:10 PM   #24 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. for eyes closed, you will need some time to get used to. Since all the k/b boxes come seal, it's better to test the keyboard before buying. Comfort curve keyboard (from MS) is really good once you get used to it.
What??? Logitech laser mouse for 500 bucks??
Old 22-02-2009, 09:20 PM   #25 (permalink)
Point Blanc
do not think so there is logitech lazer mouse of lesser price than MX518.
acewin is offline
Old 23-02-2009, 02:36 PM   #26 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I saw it amazingly in a newspapers MONTHS AND MONTHS ago, mabe I misread, but there were uber cheap mice for Rs. 500 each and also Rs. 300 and i saw the laser word, or did I? Now i'm getting confused!
About me:
Old 25-02-2009, 07:49 PM   #27 (permalink)
The Smaller Bang
Great. Just GREAT.
Try searching in ToI's and Hindu's archives or something.
Old 25-02-2009, 08:45 PM   #28 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^^I think I saw it when I was in Kolkata, now I've been living in New Delhi for a year!!!!
About me:
Old 25-02-2009, 10:30 PM   #29 (permalink)
Point Blanc
very good, but we surely get lazer mouse from zebronics and i-ball in 500-600 bucks.
acewin is offline
Old 26-02-2009, 12:12 AM   #30 (permalink)
The Smaller Bang
How is Zebronics ? I know a lot of guys with Zeb cabbys but nobody with Zebronics Lazer Mice.
pls suggest a good CPU-Motherboard combo within Rs.12k for a mid-range gaming machine abhishek.bandodkar Gamerz 2 22-08-2007 08:40 PM
~= Please Suggest a Good Mouse Under 1K =~ Vishal Gupta Hardware Q&A 15 11-07-2006 01:41 PM
Pls Suggest the BEST UPS, Keyboard, Mouse... Vishal Gupta QnA (read only) 11 30-08-2005 07:08 PM
Mouse Keyboard Combo royal Peripherals 11 02-08-2005 02:12 PM
