Old 13-02-2009, 06:34 AM   #1 (permalink)
Default HELP! Display Problems with new PREMIUM i7 HTPC!!!
I have just put together a premium HTPC... First time build.. of the following components:
Thermaltake DH-102 w 7' touchscreen
ASUS P6T Deluxe
i7 920 w Stock Cooler
6gb RAM
Sapphire Radeon HD 4870 512mb ddr5
LG Super Multi-Blue BD/HDDVD/dvd optical Drive
WD 500gb HDD 7200 rpm
Asus Xonar D2 7.1
Dual HD TV Tuner
Wireless Adapter
550w PSU
I just finished putting everything together and I went to turn the system on for the first time and I can't get anything to display or any type of beeps from the system at initial boot to show any error. All of the components are receiving power and running. I've already tried taking it all apart, confirmed correct assembly and rechecked all connections. Still nothing. I am really hoping I can figure this out. Any ideas?
Thanks for your help.
CJust is offline
Old 13-02-2009, 07:46 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: HELP! Display Problems with new PREMIUM i7 HTPC!!!
Which psu?Awfully lot of components to claim it as an htpc.
Hardware BBQ
The Sorcerer is online now
Old 13-02-2009, 12:51 PM   #3 (permalink)
^^^ have you tried connecting with other monitor, gfx card is coneected via 2 x 6 pin connectors??
foruamit2004 is offline
Old 13-02-2009, 04:25 PM   #4 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
Make sure you have all the wires and pins connected thoroughly & post your answer
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
[HELP]Display Problems with my new PS2 !! raksrules Hardware Q&A 2 22-06-2008 07:48 PM
display problems deepak rajendran Hardware Q&A 4 27-07-2007 11:21 PM
DISPLAY PROBLEMS ravitejap Software Q&A 1 07-02-2006 09:26 PM
Problems with Nero 7 Premium kguragain Software Q&A 3 28-12-2005 10:36 AM
Display Problems justfriendz QnA (read only) 5 20-09-2004 01:32 AM
