currently i have p4 3ghz,512mb ddr1,intel 915mobo...
i want to upgrader my system to play games and be more "graphically pleasant"
pl suggest me upgrading options...(in 10 - 15k range)
tanx...
the config by foruamit2004 seems fine.. though u can consider changing a few things...
- go with 667mhz ram instead of 800mhz - will save money. the c2d e5200 won't really be able to make much use of the extra 133mhz.
- for better performance, consider dual channel memory i.e. 1gbx2 rather than 2gbx1.
- u could use the hdd of ur current system. if that seems too less, u can go for a seagate or samsung 250gb sata hdd.
- u might be able to do with ur current psu as c2d requires quite lesser power than the p4 and adding the gpu shudn't tip the scales much. just check the power requirements of the c2d, p4 and the 9600gt.
Using a 17" MacBook Pro
Running Mac OS X Lion and Windows 7 Ultimate
Hardware: Core i5 M540 @2.53GHz; Nvidia GeForce GT 330M 512MB; 8GB RAM; 500GB HDD
u might be able to do with ur current psu as c2d requires quite lesser power than the p4 and adding the gpu shudn't tip the scales much. just check the power requirements of the c2d, p4 and the 9600gt on the net. not too sure about the exact requirements.
