Old 12-02-2009, 05:12 PM   #1 (permalink)
Question core i7 fastest PC or dell studio xps desktop ?
intel sells core i7 pcs starting from 48k but do any one has bought it ? i mean how is it?
my another query is that the retailer says that they will assemble in their shop so will it be ok ? is there any utility available that will check if the rig is GENUINE or not ( mean i7 processor and ram ) according to the r/q of intel ...
the dell studio xps DESKTOP ( with core i7 ) is another choice starting from 79k but has full hd 24'' monitor and xps premier service...
suggest me digit!
budget should be under 80k-85k
waiting for answer ...
samninc is offline
Old 12-02-2009, 05:23 PM   #2 (permalink)
Default Re: core i7 fastest PC or dell studio xps desktop ?
well i would suggest you go and buy all the parts yourself.. that way you know what you are getting is the real deal..
then you can either assemble it yourself, or you can have some1 assemble it for you..
and 80-85k is a very good budget.. you should easily get a good config..
the thing about branded pcs is that they will turn out to be much more expensive that they would be if u have the pc assembled.
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
fuzzz is offline
Old 12-02-2009, 05:24 PM   #3 (permalink)
but my concern is that will they all be original ?
samninc is offline
Old 12-02-2009, 05:40 PM   #4 (permalink)
techygeek's Avatar
Get the parts from a trusted vendor and check the warranty and ensure all the parts are box packed
Don't worry you will get everything genuine if u buy from a reputed shop
techygeek is offline
Old 12-02-2009, 05:40 PM   #5 (permalink)
Intel OCer
amitash's Avatar
^they will obviously be orriginal if you buy it from reputed dealers or online shops...Just ask for bill on purchase.
for 85k Its better to build a PC yourself...I would suggest:
1.core i7 920--14k
2.gigabyte GA-Ex58-UD5 (extreme not available in india)--18k
3.corsair 3gb ddr3 1333--7k
4.Ati HD4850 crossfire--17k
5.Atleast 500GB HDD--3k
6.Tagan BZ800--8k
7.dell 22" monitor--15k
8.Loigtech MX518---1.3k
9.Dvd burner--2k
total: 85.3k
My site: collegeclassroom.org
amitash is offline
Old 12-02-2009, 05:44 PM   #6 (permalink)
what is intel certified workstation or desktop?
do they get orders online or by phone?
this forum has actually has something new...
thanks
got my answer
samninc is offline
Old 12-02-2009, 06:26 PM   #7 (permalink)
Admit it either a noob OR a crorepati will buy 80k xps desktop(waste of money )...
""intel sells core i7 pcs starting from 48k "" --- who told you that intel sells pcs???
Intel sells only processor/motherboard...
If you assemble ur PC by yourself with the correct parts then it will be much better then dell xps any day..in a assembled PC every component can be selected from the best available in the market with 3-5 years of warrenty..even in a dell pc main components(proccy,mobo,ram,hdd) will be of other companies..
Now for a reference you can assemble a pc like this in 80k
Motherboard: Gigabyte GA-Ex58-UD5
Processor: Intel 1.core i7 920--14k
Memory: DDR3 gskill or crosair whichever you can find cheaper, 4gb or 6 gb - 6-10k
Video: eVGA GeForce GTX 295 2GB 31k / or GTX 285 ~ 22k
Audio: Asus Xonar 4.5k
Storage: Western Digital 10EACS 1TB 5.4k
Cabinet: Antec 1200 /Cooler Master HAF
Power Supply: CORSAIR CMPSU-750TX 8.5k
Optical Drive: L.G. GH22NS30 SATA/Samsung SH-S22F SATA 1.1k
Speakers: Your choice
Display: Dell 22" 2209 WA - 20k (full HD, excellent review)
Input: Logitech Logitech G15 Version 2 Keyboard and Razer DeathAdder
Mouse Pad: Razer Goliathus Large
Just check the specifications and compatibility
foruamit2004 is offline
Dell Studio 15 Review mukul Reviews 18 24-04-2009 12:27 AM
Dell Studio XPS 13 & 16 Laptops aytus Reviews 13 21-01-2009 10:58 AM
Better Laptop:Dell Studio 15 or HP dv5-1015TX ? Champ Hardware Q&A 8 07-12-2008 08:45 AM
DELL XPS or Inspiron or Studio s18000rpm Hardware Q&A 16 15-10-2008 09:44 PM
DELL Studio Or XPS ? naveen_reloaded Mobiles and Tablets 23 14-07-2008 01:32 AM
- by c4u
