Old 12-02-2009, 01:23 PM   #1 (permalink)
~It_is_Andrew~'s Avatar
Default Need help deciding on external storage
I have been using a assembled 80GB 2.5" external HDD for past 4 years.Now I am in need of a bigger & reliable external storage rather than sending lots of time in organizing & burning backup dvds.
Brand-wise I'm inclined towards Seagate or Western Digital. I am having problem deciding whether should I go for a 2.5" or 3.5" solution.
I want reliability and bigger storage. The speed should be good enough to carry out day to day backup & other things (watching movie directly from the hdd etc)
I would be happy to get a solution in range of 6-7K but not at the cost of reliability.
Which options should I consider? Will buying a 3.5" sata2 HDD & a casing will be an reliable option?
Please suggest. (My post is little disoriented but I'm little confused)
Regards,
Andrew
~It_is_Andrew~ is offline
Old 12-02-2009, 07:15 PM   #2 (permalink)
Default Re: Need help deciding on external storage
3.5" external HDD are ok only if you don't move it around here and their.. i have not seen any 3.5" external HDD survived for much long.. if portability is an issue then buy WD passport 320 Gb ~ 4k, OR else you can buy 3.5 " WD Green power 1 TB ~ 5.3k
foruamit2004 is offline
Old 12-02-2009, 07:21 PM   #3 (permalink)
thanks for the reply foruamit2004
you mean they are niot really reliable for storage?
I was also considering assembling one? will it be a good idea?
what will be the cost of a max size portable laptop hdd (500GB i guess) assembled?
anyone?
Last edited by ~It_is_Andrew~; 13-02-2009 at 10:13 AM. Reason: Automerged Doublepost
Old 13-02-2009, 10:17 PM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
dont worry buddy..
go in for a WD 3.5" internal HDD..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
External Storage Back Up Drives raajeish Hardware Q&A 3 22-01-2009 08:51 AM
external storage laptop HDD Sridhar_Rao Laptops and Netbooks 1 25-06-2008 12:46 PM
Need an external storage device. eddie Hardware Q&A 9 28-07-2006 10:37 AM
images direct to external storage(pendrive,hdd) plz help! techmax QnA (read only) 3 15-02-2006 12:52 PM
External storage medium. amitsaudy QnA (read only) 5 16-12-2004 04:52 PM
- by c4u
