Old 11-02-2009, 10:38 PM   #1 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
Default What's wrong?? Please help!!
hi, here's the problem: when my cous was playing gta sa, he said he heard two beeps and the system was shut down. When he switched on the monitor gave 'No Signal'. He reinserted 9800GTX+ but the monitor gave him no signal, he reinserted the ram also, but no. He even took out the cmos battery and inserted again nothing. What's the problem, guys. He can't test his card with my rig, 'cause i am on a holiday. Please tell me a solution guys. He's worried. Thank you in advance
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 11-02-2009, 10:53 PM   #2 (permalink)
ambar.hitman's Avatar
Default Re: What's wrong?? Please help!!
most probably RAM or SMPS is faulty. But as monitor is showing no signal, i doubt its RAM problem. Ask him to try with different RAM
ambar.hitman is offline
Old 12-02-2009, 12:02 AM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
RAM or SMPS problem, check both.
Blogging at:
Technostarry
saqib_khan is offline
Old 12-02-2009, 01:19 AM   #4 (permalink)
Ethan_Hunt's Avatar
Try and isolate it with the graphic card as well.
V for Vendetta
Ethan_Hunt is offline
Old 12-02-2009, 06:37 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
1. Tell your friend to re-insert ram sticks.
2. Try with different Ram.
3. Try with a different Gfx card.
4 Try with a different PSU.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 12-02-2009, 06:40 AM   #6 (permalink)
CG Artist
gaurav_indian's Avatar
I had a same problem 4 months ago.I also thought RAM was at fault.But my motherobard,gfx card and RAM all were dead due to overheating.
gaurav_indian is offline
Old 12-02-2009, 10:18 AM   #7 (permalink)
Did you overclock ur system @ Gaurav?
Old 12-02-2009, 12:47 PM   #8 (permalink)
NVIDIAGeek's Avatar
^^Thank you guys for suggesting. He said RAM was the culprit. He was using 2GB RAM of Transcend & 1GB RAM of ZION, both were 667MHz. The ZION had gone nuts . Now he's using only 2Gigs of RAM. Is it sufficient for playing games [Crysis, Fallout 3] at 4x AA 16x AF and 1440x900 res.???? Is there any difference between 2GB & 3GB in games???
CRYSIS 3 FOREVAH!
Old 12-02-2009, 01:01 PM   #9 (permalink)
damnbadman666
damngoodman999's Avatar
ya its ok ,, but try to increase
when he is using 32bitos means its ok
damngoodman999 is offline
Old 12-02-2009, 01:12 PM   #10 (permalink)
NVIDIAGeek's Avatar
Yes, 32bit OS. No probs, huh???
CRYSIS 3 FOREVAH!
Old 12-02-2009, 01:22 PM   #11 (permalink)
damnbadman666
ya ,, up to gta-4 there is no probs
dont know about future ???
Old 12-02-2009, 01:22 PM   #12 (permalink)
Yup no probs in 32 Bit OS, max 32 bit can use is 2GB RAM
Old 12-02-2009, 01:23 PM   #13 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
2GB is enough...The extra GB would hardly make a difference...
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 12-02-2009, 01:24 PM   #14 (permalink)
damnbadman666
32 bit OS use 3.25GB RAM !!!
Old 12-02-2009, 01:25 PM   #15 (permalink)
32bit or 64bit, makes no difference until you have 4GB RAM or so, since some RAM is not utilized.
32bit can use upto 64GB RAM with PAE...
http://en.wikipedia.org/wiki/Physical_Address_Extension
Last edited by Liverpool_fan; 12-02-2009 at 01:27 PM. Reason: Automerged Doublepost
Old 12-02-2009, 01:32 PM   #16 (permalink)
damnbadman666
the default 32bit OS only uses 3.25 GB
there are many modds r there to convert the 32bit os to recogonize 32gb RAM
Old 12-02-2009, 02:57 PM   #17 (permalink)
NVIDIAGeek's Avatar
Does Crysis will be sufficient with 2GB??? At 4x AA & 16x AF 7 1440x900 res. ???
CRYSIS 3 FOREVAH!
Old 12-02-2009, 07:00 PM   #18 (permalink)
^^^ just remove the 4xAA part..it will work with good gpus like 4850 or 9800gtx+.. btw 4xAA won't even work on gtx 260..
foruamit2004 is offline
Old 12-02-2009, 07:45 PM   #19 (permalink)
Intel OCer
amitash's Avatar
Yea forget about aa in crysgs
My site: collegeclassroom.org
amitash is offline
Old 12-02-2009, 10:24 PM   #20 (permalink)
himadri_sm's Avatar
i played crysis at very high settings but with 2x AA & crysis: warhead at enthusiast settings & 2x AA on my hd 4850..without any crashes or freezing whatsoever.
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline
Old 12-02-2009, 10:27 PM   #21 (permalink)
Fast 'N' Furious
topgear's Avatar
@ nvidiageek - tell your friend to buy another 2 GB stick & run both 2GBs in dual channel. They will give better perf in games.
topgear is offline
Old 13-02-2009, 12:56 PM   #22 (permalink)
NVIDIAGeek's Avatar
"tell your cousin" . 32-bit OS uses 3.25GB RAM, right?? But is 4GB RAM utilized by the 'demanding' games on 32-bit OS???
"CRYSiS". Why?? I have played with 4x AA with High settings & Crysis WARHEAD with Enthusiast settings & at same AA [DX9]. No probs.
CRYSIS 3 FOREVAH!
Old 13-02-2009, 02:45 PM   #23 (permalink)
^^^ you are not eligible to say that....hardly anyone has sig like your
@sekhar CRYSIS - simply not possible, i'hv almost same setup as yours and cpu/gpu well overclocked. in benchmark tool you might get 30+ fps, but gamepaly won't be smooth with very high+2AA
Old 13-02-2009, 04:18 PM   #24 (permalink)
NVIDIAGeek's Avatar
^^Rig in the Sig [] is my brother's. It's supremely fast! I can't wait when he comes back to India.
@foruamit2004 - What's not eligible, I didn't understand??? . I've played Crysis at above quoted settings with my Rig. Which's Intel C2D E8400@3.0GHz, 2GB RAM 667MHz, PALiT Radeon HD4850 Sonic, Intel DG31PR []
CRYSIS 3 FOREVAH!
Old 13-02-2009, 08:48 PM   #25 (permalink)
Fast 'N' Furious
topgear's Avatar
Buddy that's not true. 32 bit OS doesn't have 3.25GB mem limitation.
For eg. Windows Server 2003 32 bit Enterprise Edition SP2 Supports 64GB Ram.
Windows Server 2003 32 bit Datacenter Edition SP2 Supports 128GB of Ram.
But, 32 bit consumer grade OS like Vista & XP 32 bit editions have such limitations.
For 4 GB Ram - I've said to get 2x 2GB Ram & Run them in dual channel. Coz Dual Channel does gives 15-30% more bandwidth compared to single channel.
So all memory intensive apps will run faster.
32 bit programs can support a max mem of 2GB. So games & other programs
which can utilise 2GB ram will benefit even more.
Also you can always go for 64bit OS & get more performance.
topgear is offline
Old 14-02-2009, 01:08 PM   #26 (permalink)
NVIDIAGeek's Avatar
If I switch to 64-bit OS, does 32-bit games uses the performance of 64-bit OS??? Or do I have to buy 64-bit Games?? Do Games switch to 32- or 64-bit when we change the OS 32- or 64-bit???
CRYSIS 3 FOREVAH!
Old 14-02-2009, 01:23 PM   #27 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^Dun worry, the work. And only if the game is 64-bit optimized(it's usually mentioned), then it benefits from the 64-bit OS. Else only the xtra ram comes in2 use.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 14-02-2009, 06:05 PM   #28 (permalink)
NVIDIAGeek's Avatar
Thanks, budd [offtopic: Tell me some games which has some best ending]
CRYSIS 3 FOREVAH!
Old 14-02-2009, 10:05 PM   #29 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Depends, try Fallout 3, nice game.
Left 4 Dead
COD 5
About me:
Old 16-02-2009, 12:22 PM   #30 (permalink)
@nvidia... Guess, i'm not that lucky...offcourse my crysis copy was not that well ***** and was without patches..
What's wrong with my IE7 ? Nariman Software Q&A 1 23-09-2007 05:56 PM
Is there anything wrong with the Log File readermaniax QnA (read only) 1 23-02-2006 07:28 PM
Something gone wrong with ''My Computer'' shyamno Software Q&A 2 24-01-2006 09:20 PM
What's wrong with CPU-Z ? mohit CPU / Motherboards 2 11-04-2005 11:44 AM
What's wrong with the cd? callsriram QnA (read only) 14 09-11-2004 07:00 PM
- by c4u
