Old 09-02-2009, 07:57 PM   #1 (permalink)
toofan's Avatar
Default Connecting Two PC for Playing COD 5 in LAN
Hello Friends,
I want to connect two PC's to Play the gamming in LAN with my bro. How can I connect the two PC's.
I have one router available. + two cables which are used to connect PC to the Broadband modem.
And Please also tell me the steps to configure the XP in both PC for using it.
Thanks.
Can any one reply how to set up a lan between two PC.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 10-02-2009, 08:30 AM   #2 (permalink)
Default Re: Connecting Two PC for Playing COD 5 in LAN
It is very simple connecting LAn between 2 computers, this is what I have done at home to play multiplayer games between 2 PC's
You can buy a cross cable at around 30 rs and connect both the pc's using it.
Once done.
Right click on the taskbar icon of 2 computers showing lan.
Change the Ip of both the computers , for eg
192.168.5.20
and
192.168.5.23
now add subnet as 255.255.255.0
and gateway as 192.168.5.40 (common for both)
then disable any firewalls that stop the lan access or monitor it. (sometimes causes issues)
And that's it your done.
to check you can ping too or make folders sharable.
Visit http://gfxpixels.co.nr for free custom graphics!!
aquafusion is offline
Old 10-02-2009, 11:10 AM   #3 (permalink)
Once done.
192.168.5.20
and
192.168.5.23
lan is ok... but when we do this in xpsp2 and then while trying to dial broadband with old settings, it shows generic host error. how to avoid this?
ajith025 is offline
Old 10-02-2009, 11:27 AM   #4 (permalink)
^^ have never come across that error, but you could check the link below
http://support.microsoft.com/kb/894391
Old 10-02-2009, 11:34 AM   #5 (permalink)
^^ i tried all the hotfixes from microsoft... it didnt work...
later i had to install windows so that i could connect to broadband...
LAN will work if its connected through router. but direct connection is not possible
ajith025 is offline
Old 10-02-2009, 11:42 AM   #6 (permalink)
what do you mean that it will not work when direct connection is made ? r u referring to the cross cables ?
Old 10-02-2009, 12:58 PM   #7 (permalink)
^^ yes.
ajith025 is offline
Now Playing jamyang312 Chit-Chat 505 13-08-2009 11:29 AM
DVD playing in DVD Player but not playing in PC saqib_khan Hardware Q&A 4 30-06-2008 09:46 AM
Playing on LAN??? cooldip10 Gamerz 1 21-03-2006 01:52 PM
- by c4u
