Old 09-02-2009, 11:02 AM   #1 (permalink)
The Tech Enthusiast
Default Building an HTPC
Hi guys,
I am planning to buy a new computer in March. I already own a computer and was thinking of converting it into an HTPC. Here is the configuration:
Mobo: Asus K8N-VM
Processor: AMD Athlon 64 3000+ (Clawhammer Core)
RAM: Hynix 512mb DDR400 x2
HDD: Seagate Barracuda 80GB PATA
Optical Drive: LG DVD-RAM Drive
SMPS: VIP 400W
If I add in a discreet graphics card, do you think the rest of the PC can handle HD content?? If yes then please suggest a good HTPC card. If not then please suggest the changes that can be made in this config.
piyush2202 is offline
Old 09-02-2009, 11:54 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Building an HTPC
A low profile card below ati 4670 should do the job.
Hardware BBQ
The Sorcerer is online now
Old 09-02-2009, 04:31 PM   #3 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
+1
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 10-02-2009, 10:41 AM   #4 (permalink)
The Tech Enthusiast
what about the nvidia geforce 8400GS??
Old 10-02-2009, 10:56 AM   #5 (permalink)
Ati is known for low power consumption on idle mode and their onboard/ low profile cards are much better options against nvidia. Ati has higher IQ levels and on the real time observation ati scales much better than nvidia. Not that I am saying nvidia 8400gs is crap, considering its for htpc, but you are getting the quality for the same price as well.
Hardware BBQ
Old 10-02-2009, 01:11 PM   #6 (permalink)
NVIDIAGeek's Avatar
+2, Again
CRYSIS 3 FOREVAH!
Old 11-02-2009, 01:21 PM   #7 (permalink)
The Tech Enthusiast
thanks for the help guys. any more suggestions are still welcome. I have till march
Old 11-02-2009, 01:29 PM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
Ati HD 4670 is HTPC => compliant
damngoodman999 is offline
Few questions on HTPC raksrules QnA (read only) 3 04-12-2008 04:56 PM
Budget HTPC amey_dude Hardware Q&A 8 08-10-2008 10:22 PM
My HTPC - the long brief Ponmayilal Reviews 39 21-04-2008 07:13 PM
HTPC configuration sarulan PC Components / Configurations 3 18-11-2007 11:49 AM
HTPC suggestion hitman050 Hardware Q&A 1 19-05-2007 12:45 PM
- by c4u
