Old 09-02-2009, 06:53 AM   #1 (permalink)
Default Suggest me a Desktop {Max Rs.55,000}
Please suggest me a desktop config that should not cross 55k....It can reach 55k
Primary Purpose is gaming and video encoding...
I am planning to buy it this thursday @ Hyd..
Forget UPS,Keyboard,Mouse and Speakers...I have them
Urgent...PLease help.......
racevthme is offline
Old 09-02-2009, 01:49 PM   #2 (permalink)
Default Re: Suggest me a Desktop {Max Rs.55,000}
What purpose...is this rig being build for...?
krishnavamshi24 is offline
Old 09-02-2009, 02:37 PM   #3 (permalink)
Generally .. i need to buy a desktop vch shud run windows 7 {Ofcourse same compatability of vista} ... i use it for video encoding , play high end games......
Old 09-02-2009, 05:33 PM   #4 (permalink)
Boy Genius
prateekchanda's Avatar
I'm Thinking of building a new system on the following lines
1). E8400 - at Rs.8690
Or
. . .E7300 - at Rs.5800
Or
. . .Q6600 - at Rs.9690
Will OC <- So which is better bang for buck? considering extra cost of aftermarket cooler if required
2) Palit HD 4850 at Rs.8800
3) GA-EP35-DS3L at Rs 4800
4) Samsung 2253BW @ Rs 11700
5) Vx450W - Rs. 4000
Or
. . .CoolMaster 600W - Rs. 3200
6) 4 Gigs (2g x2) Transend/Kington @ Rs2400 < -can i use them at 4-4-4-12, these are 5-5-5-15 Value ram
7) Altec Lansing VS3251 at Rs 4000
My budget for all (inc UPS , K/b mouse Etc.) is 50K
So what do u think guys is it a cool rig or any improvements that u can think of!
My Uses Are Gaming Crysis, NFS, COD etc. Virtualization - Lots of it! i.e VMWare, Gynamips etc
I would like to stick to Intel and wish new Phenom II will push things down
1. phenom II 920: Rs. 11500
2. Q9300-q9400 : Between 11000-12000(appx)
Q8200 @ 2.8 Ghz, GA-EP45C-DS3R, Palit HD4850, WD 1TB Black, 4x2GB 5-5-5-15 800(1:1) Mhz Kingston, VX2439wm (24inch,2ms, C.R 1000(typ), DVI), Creative 5.1, Corsair Vx450W - Prateek Chanda
prateekchanda is offline
Old 09-02-2009, 05:53 PM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
^^Purpose ? You are switching between quad cores and dual cores like there's no difference between them. Decide what you want first.
If you want a Bang-For-Buck overclocker, wait for AMD Phenom II X3 720 Black Edition. Will come under 7K with unlocked multiplier and great overclocking potential. Already released in UK, expected soon in India.
For lots of virtualisation stay away from Dual Cores.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 10-02-2009, 02:45 PM   #6 (permalink)
Boy Genius
'Guess ur rite will wait a week or 2
btw off late proceccy prices are shooting up! hope waiting wont harm
Old 10-02-2009, 04:42 PM   #7 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
^^If you need it right now. It's better to go for Q8200. Don't know if prices go low or up, it's better if you get it now. No one knows when AMD Phenom II X3 720 BE comes to India.
CRYSIS 3 FOREVAH!
NVIDIAGeek is offline
Old 03-03-2009, 04:30 PM   #8 (permalink)
Boy Genius
Thank You all for ur valuable suggestions Got my Machine yesterday from Nehru Place
Q8200 -Rs8790
GA-EP45C-DS3R -Rs 8600 <- 2 PCI, e-sata, Raid, DDR3 + DDR2(16GB), PCI-e 2.0, Ultra Durable and EP45-DS3R is not available
Palit HD 4850- Rs8500 <- Best price at NP no one was giving below that not even the distributor
WD 1 Tera Byte Caliver Black - Rs 6500
Viewsonic 22" 2235wm-5 DVI, 2ms, 1000 CR(typ) - Rs 10500
Cabinet I-Ball Gamer Rs 1100 with out SMPS
Corsair Vx450W - Rs 4000
2x2 GB Kingston 800Mhz 5-5-5-15 1.8v - Rs 2200
DVD Samsung 22x sata - Rs1050
Microsoft Comfort curve 2000 - Rs 950
Luminous UPS (double Battry) 800VA - Rs 2500
Altec Lancing 5.1 VS3251 -Rs 4040
Total :- 58,600/-
Old 03-03-2009, 05:00 PM   #9 (permalink)
RMN
cngrts mate!
is that mobo Gigabyte?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 03-03-2009, 08:53 PM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Good config, bad CPU unless you OC.
U shud have spend 1k more and got the HD4850 SONIC. There's a reason SONIC is popular. It run's MUCH cooler.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 03-03-2009, 09:47 PM   #11 (permalink)
Intel OCer
amitash's Avatar
Extend to 60k and you can get the best:
core i7 920--14k
Gigabyte UD3R--14k
Corsair tri-channel 3gb ram--7.5k
Msi HD4870--12.5k
BenQ 22" monitor-10k
samsung sata dvd writer--1.1k
For video encoding, nothing comes close to the i7 with its 8 logical cores... As for gaming, the HD4870 is very vfm and you can play every game easily... I highly suggest you extend your budget and get this...plus its future proof too.
My site: collegeclassroom.org
amitash is offline
Old 17-03-2009, 11:20 AM   #12 (permalink)
shashank4u's Avatar
Q8200 -Rs8790
Total :- 58,600/-
which shop did you get the palit from??
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Suggest Desktop pc below Rs.30,000 metcode Hardware Q&A 15 18-12-2008 01:28 PM
Suggest a good Branded desktop PC gurujee QnA (read only) 2 26-08-2007 12:17 AM
Suggest Desktop damnthenet QnA (read only) 5 28-05-2007 11:08 PM
Suggest Desktop Pc damnthenet Hardware Q&A 1 28-05-2007 10:39 PM
- by c4u
