I got a Samsung SH-S203D Optical Drive & from the last 15 days it is not reading some of my DVDs. Sometimes it does, sometimes it doesn't. I tried cleaning the lens but still no solution...I wanted to ask some things
1) A New Optical Drive costs Rs 1000, is worth repairing & should I just buy a new one?
2) Should I buy an Internal Optical drive at all? Other then backing up my downloaded T.V Shows i have no other use of it.
3) How is the performance of an external Optical drive? I can either buy a native external drive or buy an internal drive with External drive casing. This way I won't have the drive installed all the time & will use it only when needed.
