Old 08-02-2009, 03:30 PM   #1 (permalink)
Question Connect Notebook to TV
Hi All,
I have Compaq Presario V6608AU Notebook PC with Svid out its 7Pin Port.
I have AV in port in my Smasung Ultraslim TV.
I bought a 7Pin(SVID) to 3RCA (AV in)cable. & connected the same to my Notebook & TV.
But I am not getting any screen on my TV..!!!!!!!!!!!
Please tell me what should I do.
Regards
Sudhir
Sudhir
kbsudhir is offline
Old 08-02-2009, 09:35 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Connect Notebook to TV
You need to enable the TV Out from the display drivers if you are on Windows.
infra_red_dude is offline
Old 08-02-2009, 10:36 PM   #3 (permalink)
Exclamation Re: Connect Notebook to TV
Thanks,
But I am not able to find any options where I cam enable my S-Video out. Its because either its already enabled or I am not able to find that option.....!!!!!!!!!!
Also the model# of my TV is CS29A730
Link:
http://www.samsung.com/in/consumer/d...CS29A730ELTXXL
Is it because its not possible to connect a laptop to TV i.e S-Video(out) to AV(in) using S-Video to AV Cable.
Also I think my Laptop is able to detect my TV as all the controls are getting tranferred to secondary display. But my TV is not displaying the same.
Regards
Sudhir
Sudhir
kbsudhir is offline
Old 09-02-2009, 01:09 AM   #4 (permalink)
Wire muncher!
No, an s-video to a-v connection works just fine. The s-video connection needs to be enabled from the graphics setup program (if nVidia then the Forceware panel, if ATi then from the Catalyst CC).
Also make sure you are connecting to AV-in in your TV and selecting the proper AV mode.
Old 14-02-2009, 06:13 PM   #5 (permalink)
Guys,
After a week long of failed attempts, here is the latest update.
My Laptop is detecting the TV as a display & transfering the dipsly to my TV.
BUT my TV is not displaying anything...........!!!!!!!!!!!!!!!!!!!!
Guidance needed.
Thanks
Sudhir
Sudhir
kbsudhir is offline
Old 15-02-2009, 09:18 AM   #6 (permalink)
Wire muncher!
You need to put the TV in proper AV mode.
Can I connect 2 internet connections Connect at a time? gaju6696 Internet & WWW 6 06-02-2009 08:26 PM
Notebook PC dhanusaud Laptops and Netbooks 3 03-05-2008 06:37 PM
How to connect my PC and my Notebook? talkingcomet QnA (read only) 7 01-05-2008 10:07 PM
Notebook for 45k the_moon QnA (read only) 5 16-11-2006 03:19 PM
- by c4u
