Old 07-02-2009, 06:58 PM   #1 (permalink)
Question (bios) usb problem
my friend have a system which has a bios password and the usb was disabled in bios. no cdrom in the system and you should do not remove the battery. is there any other solution to enable usb port....
zerocode is offline
Old 07-02-2009, 09:40 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: (bios) usb problem
No. You should rermove the CMOS battery & put it back againn to clear bios setting with password. It's the easiest method.
Or else you have to remove & put appropriate jumpers on the mobo ( consult your mobo manual for this ).
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
bios problem plz help shubh961 QnA (read only) 1 20-10-2009 04:48 PM
BIOS-Problem..PLZ help.. adit_3250 Hardware Q&A 3 07-01-2009 08:01 PM
Bios Problem Help Binuksb Hardware Q&A 2 01-09-2006 10:51 PM
Problem With BIOS anilkumar_kumar Hardware Q&A 2 24-02-2006 11:25 AM
- by c4u
