Old 07-02-2009, 06:44 PM   #1 (permalink)
Exclamation Upgrade TimE!!
Dude....
It's time for my upgrade again!! My 3 year old ASUS A8N-E mobo failed times in a week so I am off to get me a new SET
So people, please suggest some great config for me.... either intel or AMD is welcome ... My budget is currently Rs.30000. What I need is a mobo, proccy, ram and maybe a GFX card, tho it's not a must ....
My current/existing config are"
CM 331 Elite cabinet
ASUS DVDRW optical drive
CM Extremepower 600W
Seagate 750 GB HDD
Creative Audigy Soundcard
nVidia 8600 GT (gotta upgrade it
I use my system mainly for GAMES, although I may use it for some project on DBMS in the future... (read ORACLE)... I hope i have provided enough info... If not, please feel free to ask....
Thanks all!!
Ultra_Bloodshed is offline
Old 07-02-2009, 09:51 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Upgrade TimE!!
Config : 1 ( Recomended )
Intel Q8200 Rs. 8800
MSI P7NSLI PLATINUM Rs. 8800
2x Palit 9800GT For SLI Rs. 14600
2x 2GB Transcend DDR2 Ram Rs. 2400
This config will give you very good performance in gaming.
Or else
Config : 2
Asus P5Q Pro Rs. 9500 or MSi p45 NEo F Rs. 6000
Palit 4870 Sonic 1Gb Edition Rs. 17500
2x 2Gb Transcend DDR2 Ram Rs. 2400
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 07-02-2009, 10:14 PM   #3 (permalink)
RMN
@topgear
is CM extreme 600W enough to power Config 2?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 08-02-2009, 07:26 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Some people Run their rig with CM600W flawlessly
Though I would suggest Corsair TX650W Power Supply or
Tagan BZ600 @ Rs. 7000 & 6000 respectively.
Here I'm giving a alternative config for Him :
MSI P45 Neo F Rs. 6000
2x 2GB Transcend DDR2 800Mhz Ram Rs. 2400
MSI 9800GTX+ OC edition Rs. 12000
Total Rs. 29200.
Which CM600W can handle easily.
topgear is offline
Old 08-02-2009, 04:45 PM   #5 (permalink)
is the MSI P45 NEO board good?? What about an ASUS P5Q-E or a Biostar one? also Is there some kinda problem with the CM 600 W PSU?? cause i heard that they are not that good and tends to kill a machine
Old 08-02-2009, 06:28 PM   #6 (permalink)
Project Halcyon V2.0
tkin's Avatar
Asus P5Q mobo series are best.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is online now
Old 08-02-2009, 06:43 PM   #7 (permalink)
Intel OCer
amitash's Avatar
1.Gigabyte GA-MA78GPM-DS2H--6.5k
2.phenom 2 920--13k
3.Palit 9800gtx+--11.5k
4.Transcend 4gb ram--2.6k
Total--34k
My site: collegeclassroom.org
amitash is offline
Old 08-02-2009, 08:04 PM   #8 (permalink)
better than biostar or MSI??
and amitabh, as a gamer, should I opt for intel core2 or AMD phenom II??
Old 08-02-2009, 10:05 PM   #9 (permalink)
Intel OCer
amitash's Avatar
^currently the phenom 2 920 is much faster than core 2 quad Q8200...And its easily overclockable so I would suggest a phenom2+780 combo over intel at your price range...
P.S. Its amitash not amitabh
amitash is offline
Old 09-02-2009, 06:48 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
2.phenom 2 920--13k
Total--34k
Hey good suggestion buddy but one thing
Instead of Palit I would recommend to go for Zotac 9800GTX+ which is only Rs. 11150 & comes with XII Century - Death or Glory game bundled.
topgear is offline
Old 09-02-2009, 11:30 AM   #11 (permalink)
ok ppl... Please help me decide then....
Intel Core2Duo E8400 @ 3GHz OR AMD Phenom II 920 @ 2.8 GHz??
if intel, is Asus P5Q-E better than Biostar TPi45??
And if AMD, is there any better M/B and should i go for ATi or nVidia?
-----questions....questions.....
Old 09-02-2009, 11:48 AM   #12 (permalink)
The Sorcerer's Avatar
Ahem!! People need to check something about the biostar i45 before considering asus series. See something kickass in this cpu-z validation link
http://valid.canardpc.com/show_oc.php?id=434920
Before people talking about credibility and all, let these links and benchmarks do the talking:
http://www.xtremesystems.org/forums/...d.php?t=190070
Hardware BBQ
The Sorcerer is online now
Old 09-02-2009, 11:54 AM   #13 (permalink)
^^ Thanks sorcerer for that input I think biostar is the way to go
But what about the choice between intel and amd?? Which will be better for gaming?
Old 09-02-2009, 12:04 PM   #14 (permalink)
Stick to intel since you have the budget. Get the e8400 s-spec slapc which is an E0 stepping- provided you can find it. You should see the s-spec model on the sticker of the intel processor's box near the barcode. M0 stepping (I think their s spec is slavc but not sure) are stubborn OCers and they are times they give really sad OC clocks. Get cl4 rams from g skills or corsair xms 2. G skills usually give powerchip ICs and corsair xms2, as far as I heard- its either elpida or powerchip ICs. In any case, cl4 is the way to go now. They do give cl4 latency at 1.8~1.9v so there's some room for ocing as well. Its high time you ditch that power supply before getting a graphic card.
If you are buying a card in the ranks of 4870 1GB ddr5, vx550 corsair or Real power 550 coolermaster are good choice. Corsair uses seasonic OEM and RP 550w uses acabel OEM psu as for now.
Hardware BBQ
Old 09-02-2009, 12:49 PM   #15 (permalink)
Intel OCer
amitash's Avatar
^Why stick to intel when AMD is performing better for his budget range?...P2 920 is a quad core procy which I think will provide huge boosts in gaming in the coming months as nearly every game is quad optimised...For your budget AMD is the way to go..would only suggest intel (in indian prices) if you had a budget for core i7 as core2quad price cuts havent been seen here...AMD's stock cooler is also awesome..people have been OCing their P2-920s to 3.6-3.7Ghz with stock....couple this with a 9800gtx+ and you have a very good gaming rig which will last quite awhile.....I bet in another 3 months you will be seeing ppl going quad all the way....And in gaming the phenom 2 quads will kick the E8400 easily in all the latest games.
As for the mobo, I think the gigabyte one i suggested is very good value for money.
Cool I didnt know the zotac one was abit cheaper...He can go for that.
amitash is offline
Old 09-02-2009, 02:17 PM   #16 (permalink)
^ is phenom II quad easily and readily available?? I am unable to find a Phenom II 920 in either itwares.com or techshop
Old 09-02-2009, 02:44 PM   #17 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
dude go for Phenom II ... i just purchased it and performance is great when it comes to gaming.....
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 09-02-2009, 09:20 PM   #18 (permalink)
Fast 'N' Furious
topgear's Avatar
@ Ultra_Bloodshed - Get phenom 2 with Biostar 790GX mobo. Its more feature rich than 780G mobos.
Phenom 2 performs better than C2Ds & should be compared with intel core i7 cpus.
A user bought it in here & he is very happy with it :
http://www.thinkdigit.com/forum/show...4&postcount=28
topgear is offline
Old 09-02-2009, 09:47 PM   #19 (permalink)
Intel OCer
amitash's Avatar
phenom 2 is available at lynx-india
LOL dont even think about comparing with core i7...when it comes to high end performance intel reigns supreme...phenom 2 is not even better than all the core 2 quad cpus...the Q9550 and the extreme series beat it.
core i7 920>>>>core2extreme qx9770>>>q9650>>q9550>Phenom 2 940>Q9450,Q9400>phenom 2 920>Q9300,Q8200
amitash is offline
Old 09-02-2009, 10:18 PM   #20 (permalink)
Fast 'N' Furious
topgear's Avatar
@ amitash - Thanks for the heads up.
Toms Hardware benchmarked a core i7 vs. phenom 2 940. . They have not put any Q9xxx in between.
And the benchmarks they conducted for AMD using DDR2 mem. They used 3.8Ghz clock speed for core i7 & 3.64 Ghz for phenom 2 ( since higher clock speed was not stable )
So I thought about the caomparision between core i7 and phenom 2.
& said that phenom 2 is better than all C2D's like C2D 8xxx series ( which is highest in Core 2 Duo family ).
And thanks againg for clearing the facts.
topgear is offline
Old 11-02-2009, 12:12 PM   #21 (permalink)
Intel OCer
amitash's Avatar
^check out anandtechs review, they give very reliable scores
amitash is offline
Old 11-02-2009, 12:21 PM   #22 (permalink)
Fast 'N' Furious
topgear's Avatar
Thanks mate. Will check it out..
topgear is offline
Old 11-02-2009, 01:30 PM   #23 (permalink)
Thanks for all your advice guys.... Refering anadtech's benchmarks, i have settled for the following config...
ASUS P5Q-E
Corsair 2x4096-6400C4DHX(4-4-4-12)(2x2GB)
Palit ATi 4850 512 DDR3
Altec Lansing VS4121 BLK
Is it good, or do you suggest any alterations??
Old 11-02-2009, 09:21 PM   #24 (permalink)
Intel OCer
amitash's Avatar
^I would still suggest you go for phenom 2 920 rather than E8400....In the gaming benchmarks the E8400 seems faster because all games are not quad core optimised...Just wait for 2 months and you will see the quad cores easily beating the dual cores...the E8400 is NOT very future proof..It will be outdated soon.
amitash is offline
Old 11-02-2009, 09:32 PM   #25 (permalink)
Fast 'N' Furious
topgear's Avatar
Those corsair rams are very good as their timings/latency is very good.
Run those mems with amd proc like phenom 2 920 as amd procs mem controler is built in the cpu unlike intel c2ds which mem controller is built in the northbridge chipset.
So you will get better mem performance with amd & the phenom 2 is better than e8400 in processing power anyday.
topgear is offline
Old 11-02-2009, 09:54 PM   #26 (permalink)
tkin's Avatar
ASUS P5Q-E
Its good, but if you're not a frequent upgrader(will not upgrade in one year from now) or do stuff like video encoding, get intel quad cores(least is Q6600, better to get Q9400 @ 12k), everything else is fine.
Core for core Intel proccy's are faster than AMD, so stick to Intel.
tkin is online now
Old 12-02-2009, 10:30 AM   #27 (permalink)
Intel OCer
amitash's Avatar
^again...core for core only intel core i7s and the 35k intel core2quads are faster than the amd phenoms.
amitash is offline
Old 12-02-2009, 04:53 PM   #28 (permalink)
tkin's Avatar
I think you don't have an update for the prices now.
A core i7(4 cores,8threads, 2.66GHz-i920) costs 15k.
A Phenom 920 X4 costs 11k.
A Phenom 940 X4 costs 13k.
AND i-920 BEATS THE HELL OUT OF BOTH OF THEM EASILY, I don't see any 35k proccies that should be needed for comparison, no one buys them these days.
Conclusion-Intel's way ahead of AMD when it comes to performance at a moderate price, a 2k extra for a large amount of performance, anyone can pay it.
But still you need to pay for a X58 mobo and DDR3 RAMS for i7 which gives AMD an edge, but with DDR3 prices falling its time for AMD to think harder.
tkin is online now
Old 12-02-2009, 05:46 PM   #29 (permalink)
Intel OCer
amitash's Avatar
I know the i7 beats AMD easily..thats why i bought one..... you will need to pay atleast 36k for a core i7 + 3gb ddr3 + x58 mobo(cheapest)
With a decent graphics card it will go upto 50k which does not fit his budget at all...DDR3 prices may be coming down everywhere but not in india..prices here stay nearly the same as they did years ago
For a budget of less than 50k AMD beats intel easily.
amitash is offline
Old 12-02-2009, 06:39 PM   #30 (permalink)
+1 above
every one is not fool if one can get 920 in 15k with no extra cost then you know what would be done..
i'd say -
Phenom II 940 -13k
biostar 790gx with acc -5k
2x2 800Mhz any good one - 2-3k
msi 4870 512mb - 13k
crosair vx 450 - 4k
sell ur cm600 ~ should go for 2k
yeah budget is slightly over.. btw you have not mentioned the monitor size, if it is less then 20" then no point in going for high value GPUs, 4850 sonic should be enough and CM 600 PSU will do fine too..
foruamit2004 is offline
Right time 2 buy\upgrade pc ??? ax3 Chit-Chat 14 04-01-2009 10:15 PM
The Right Time to Upgrade The Conqueror QnA (read only) 1 15-09-2008 11:22 PM
Is this a right time to upgrade??. gsenthil Hardware Q&A 7 19-02-2007 05:03 PM
Is This The Right Time To Upgrade??? caleb Gamerz 44 26-10-2006 06:15 PM
Is it the right time to upgrade to a DVD-Writer? a_to_z123 QnA (read only) 31 20-08-2005 07:50 PM
- by c4u
