Old 03-02-2009, 03:44 PM   #1 (permalink)
Exclamation Diff between PCI-Express & PCI-Express 2.0
ya I know that PCI-Express 2.0 is faster than PCI-Express
but can we fit an PCI-Express 2.0 compatible Graphics card in PCI-Express slot
will it work properly or it will damage the card???
Because now PCI-Express 2.0 Graphics cards are coming in market and I have motherboard which has sinlge PCI-Express slot so will the new graphics cards work on my system....
sou2008 is offline
Old 03-02-2009, 04:37 PM   #2 (permalink)
Default Re: Diff between PCI-Express & PCI-Express 2.0
yes it can..
dips_view is offline
Old 04-02-2009, 05:06 PM   #3 (permalink)
Intel OCer
amitash's Avatar
Yes it will work and you will barely see a difference between pcie 1 and 2....for my card which is pcie 2 i see a max of 10 fps difference
My site: collegeclassroom.org
amitash is offline
Old 04-02-2009, 06:44 PM   #4 (permalink)
Project Halcyon V2.0
tkin's Avatar
Unless you own a GTX260 or higher/HD4870 or higher you won't see a difference, only high end cards can max out PCI-E 1.0 bandwidth(eg-GTX280).
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Black 1TB|CM HAF 912 Adv]
[APC 1100VA|Siberia V1|PL30|X360 Controller|Noctua U12PSE2]
[G500|G110]
Adata SH14 Review(Digit Forum): http://tinyurl.com/842vpx6
tkin is offline
Old 07-02-2009, 01:17 PM   #5 (permalink)
Default Diff between PCI-Express & PCI-Express 2.0
Dear friends,
I have intel original 915 gav motherboard, p4 3.0 ghz, 1 gb ddr zion ram , 320 gb hdd,
iball 400 w smps,etc.
Recently I purchased a XFX 9500 GT graphics card of 1 GB, its a pci express 2.0 card.
whenever i am connecting the card to my system, no display is coming. but the onboard graphics is working properly. The new Graphics card is working fine on my office machine quad core, dq35 motherboard,500 w smps .
I am unable to understand whats the problem. should i upgrade the motherboard or the smps only.
Please help quickly.
thanks.
chat2arindam is offline
Old 07-02-2009, 01:48 PM   #6 (permalink)
tkin's Avatar
Originally Posted by chat2arindam View Post
Dear friends,
thanks.
Go to the bios and try to find the option for display adapter, switch it to automatic or PCI Express(if automatic doesn't work) and restart your machine, should do the job. If it still doesn't work may be there's not enough power to run the card.
[G500|G110]
tkin is offline
Old 07-02-2009, 02:39 PM   #7 (permalink)
Exclamation Re: Diff between PCI-Express & PCI-Express 2.0
Dear Tkin,
I have done all those things. My another nvidia 6200 tc card is working fine as I am connecting it to the system. But as soon as I am connecting the 9500 gt , the display is not coming, but the fan on the graphics card is rotating. The card is also becoming slight hotter like normal. I am suspecting a Smps problem. Can u please tell me which SMPS will work with it. I don't have a very huge budget. around 1500/- . Where in kolkata can i find that smps.
Thanks and regards.
ARINDAM
Old 07-02-2009, 02:50 PM   #8 (permalink)
tkin's Avatar
Dear Tkin,
Thanks and regards.
ARINDAM
Your budget is a bit low, try getting Cooler Master Extreme Power 500w for 2.5k, its available in most Chandni Chowk shops, try looking here;
M. D. Computers
23, Chitta Ranjan Avenue
Chandni Chowk
If you really have low budget try looking for Zebronics 500w SMPS for about 1.5-2k, it available in most Chandni Shops, the one mentioned is a good place to look for them.
Also you can go here;
Vedant Infosys
26, GC Avenue
Kol-700 013
Phone-2212-9832/8793, 2253-7597.
Just scout around Chandni, these are common SMPS and most shops keep them.
[G500|G110]
tkin is offline
Old 07-02-2009, 03:05 PM   #9 (permalink)
M. D. Computers
Chandni Chowk
Vedant Infosys
26, GC Avenue
Kol-700 013
Thanks tkin,
But r u sure that the 400 w smps from iball is insufficient to run my hardware. the config has been already posted above. if smps is the real culprit then i would go in for the coolermaster 500 w. is 9500gt pci express 2.0 fully compatible with 915 gav. even xfx force support team has told that 9500 gt is compatible with pci express 1 slot.
Please help.
Old 07-02-2009, 03:05 PM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Difference between them is simple and straightforward.
PCI Express 2.0 has DOUBLE the bandwidth of PCI Express 1.0.
Meaning, a PCI Express 2.0 8x slot has the speed of a PCI Express 1.0 16x slot.
But since mordern cards are much much more powerful than ever before, it now becomes quintessential to have PCI Express 2.0 16x slot if you want to use cards like HD4870 1GB, GTX 285, etc and utilise their FULL power.
All PCI Express 2.0 cards work in PCI Express 1.0 slots and vice versa.
But when you make a fresh purchase, always prefer PCI Express 2.0 (for both cards and motherboards).
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 07-02-2009, 06:01 PM   #11 (permalink)
Will Power
TheLetterD's Avatar
Default any one having?psu 400w mercury+any graphic card
Hi people,
i have a mercury 400w psu
a E7200 C2D
asus p5n mx
will i be able to run a 9500gt zotac/9600gso zotac grafic card?
pls tell if u also have same psu
TheLetterD is offline
Old 07-02-2009, 09:55 PM   #12 (permalink)
Fast 'N' Furious
topgear's Avatar
You might be able to run 9500GT
but not 9600GSO/Gt as it requiers a separate 6 pin power connector. Though you will get the necessary convertor connector with card but it's recomended to get a PSU like CM460W extreme Power atlest to use with cards like 9600GSO/Gt or higher.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 07-02-2009, 11:07 PM   #13 (permalink)
tkin's Avatar
Thanks tkin,
Please help.
It will work unless you have some defects with your mobo(like a defective PCI-e slot), no matter how much V-RAM a 9500GT can never use the PCI-e 1.0 bandwidth completetly.
[G500|G110]
tkin is offline
Old 09-02-2009, 09:59 AM   #14 (permalink)
Will Power
TheLetterD's Avatar
what abt a ati 4670
Old 09-02-2009, 09:03 PM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ HD4670 will run.
topgear is offline
Old 10-02-2009, 08:26 AM   #16 (permalink)
I think it is not a power problem.please check ur MB , GPU documentation.i hv 9500 gt on 400w smps and its works fine.consume 45w/25w peak/idle state.
Old 10-02-2009, 06:51 PM   #17 (permalink)
Will Power
TheLetterD's Avatar
dips view wazz ur full name?
Graphics Card: PCI Express x16 Detected as PCI Express Link width: 4X praka123 Open Source 2 09-06-2007 01:29 PM
PCI to PCI Express piyush gupta Hardware Q&A 8 02-03-2007 04:02 PM
outlook express defconfor Software Q&A 1 30-03-2006 11:45 AM
Diff between Visual Studio .NET/ 2005 Express edition?? raval_manoj Software Q&A 4 06-03-2006 07:34 AM
PCI EXPRESS superuser QnA (read only) 4 28-10-2004 12:20 PM
