| Forum |
#1 (permalink) |
Phenom II X4 920 Owner
Budget 25K-30K requirement processor Motherboard RAM : 3-4 GB most important Graphic Card: planning for ATI 4850 512 MB SMPS: will CM500 will be enough for this rig? kindly provide ur recomendations ... will buying next week ... and location is New Delhi so if know any Good shops in nehru place who can provide me all the parts and also at a good price will be great .... The monitor that i have is Acer LCD AL1706 VGA input so, wat saw that 4850 doesnt have a VGA input wat to do in that case ? thnks is these 2 mobos good gigabyte GA-MA78GPM-DS2H http://www.gigabyte.in/Products/Moth...ProductID=2859 Asus M3A78-EMH HDMI http://www.asus.com/products.aspx?mo...49&l3=639&l4=0
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal Last edited by prateek_san; 02-02-2009 at 01:39 PM. |
#2 (permalink) |
you will need CM600watts for HD4850 and don't worry,4850 comes with a DVI-VGA converter.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90 |
#3 (permalink) |
guys i did some searching and seems the AMD Phenom 9950 seems to be a good processor but im bit confused with Mobo .. and is this mobo gigabyte GA-MA78GPM-DS2H compatible with 9950 ? cuz in the amd's site this mobo was not listed under recomended mobo's
pls suggest me a good config guys...
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal |
#4 (permalink) |
Intel OCer
4850--9k
phenom 2 940--14k both the mobos you listed are good..you can get the asus for 6k and gigabyte for 5k. that leaves you 1-2k for RAM..get 2gb for now and add 2 more later if you want.
My site: collegeclassroom.org intel core i7-920||eVGA x58 sli||G-skill 6GB DDR3-1600| ZOTAC GTX480||Tagan BZ700||Antec 900||Logitech G15||Razer Death Adder and Megalodon |
#5 (permalink) |
i think i have changed my choice ... as i was going through diff pages i found out that core2quad is better than Phenom series ... so most probably will go for C2quad proccy , and guys pls suggest me a mobo ....
#6 (permalink) |
damnbadman666
off course Core2quad is better than phenom , but not phenom 2
dude phenom 2 reduced the price very low as u can see in NEWEGG http://www.newegg.com/Product/Produc...82E16819103471 http://www.newegg.com/Product/Produc...82E16819103472 phenom 2 920 => 9000/- phenom 2 940 => 11500/- excluding VAT if u r choosing only for gaming go for phenom 2 series , if u r using for workstation should go for corei7 but its more than ur budget phenom 2 will soon hit the whole INDIAN market , then prices will be reduced soon
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] ![]() |
#7 (permalink) |
the system will be used for Gaming purpose ....Phenom II hasnt hit the indian markets yet ?
man if i get Phenom II at those price in India i will go that ..... the thing is i will buying the system most probably next monday .....help me in buying the right RIG .... im bit confused over the mobo part though
#8 (permalink) |
damnbadman666
in such case u can go INTEL , but sure remember one thing 5 years proofing is impossible in the generation like now .
Gaming means go for core2Duo E8400 => 8700/- Asus P5q pro => 9500 PAlit HD 4850 =>9000/- total => 27200 get Thermal right ultima CPU cooler for 2500/- & Overclock to 4 Ghz ,, u ll worth it
#9 (permalink) |
ok i got the Phenom II prices from nehru place that too from SMC int.
Phenom II 920 :- 11800/- Mobo: Gigabyte 780 Chipset:- 5000 /- And ATI MSI 4850:- 9500/- is MSI card's performance good i heard that palit is the best when it comes to 4850. and Zebronics Antibiotic cab: 2150/- CM500 : 2750/- i think the rates are good enough and i can extend my budget for this Rig... probably will go for this rig on next monday any suggestions from u guys are always welcome.... thnks for the suggested Rigs...
#10 (permalink) |
cm 500 will fry ati 4850. Maybe not immidiately. But in due time. Allready someone paired a cm 500w with 4850 and now complaining that its the card's fault. Better off putting some more money and buying a corsair cx400. Active pfc, much better caps, cooling, MOVs, etc. Prevention is better than cure.
Hardware BBQ |
#11 (permalink) |
damnbadman666
Ya get Cooler master 600 watts extreme or corsair VX450
#12 (permalink) | |
damnbadman666
#13 (permalink) |
damnbadman666
the thread starter needs information on the upgrade , if u have any information regarding this one u say .
Dont bring out ur crap here !!!
#14 (permalink) | |
** pls no crap here **
#15 (permalink) |
Intel OCer
Lol spamer....i suggest you get the phenom2 config...those prices are pretty good
#16 (permalink) |
Nocm extreme series at all. Jhonyguru exposed that cm 600w is a low end seventeam 500w. But nokytech exposed that cm 650w extreme is also a low end seventeam 500w. cm extreme 460w for a non oc system. Or else something like corsair cx400 or even better vx450.
Hardware BBQ |
#17 (permalink) | |
damnbadman666
Dude i am using AMD phenom 9550 with HD 4850 on CM 600watts ,, its ok no problem at all no noise even -- good so only iam recommending ,,, & also corsair is best ,, i dont say neither poor
#18 (permalink) |
^^ Couple of links to read here:
http://thinkdigit.com/forum/showpost...2&postcount=50 http://thinkdigit.com/forum/showpost...2&postcount=55
Hardware BBQ |
#19 (permalink) |
guys hows the MSI's 4850 performance ?
cuz wat i have heard the palit is best .... becuz in nehru place thats the only 4850 available that too at SMC internation shop and corsair CX400 will that enough for the rig that im choosing.. cuz its only 400 watts?
#20 (permalink) |
damnbadman666
MSi HD 4850 is ok , but sure check the cooler type , can u post the model which is available cause cooler is the important term in the HD 4850
BTW , Get corsair VX 450 for ur rig ...
#21 (permalink) |
cx400 is enough. Just like vx450, this is a seasonic OEM- but a stripped down version of the vx450. VX450 costs as high as 4.2k-4.5k now and it used to cost 3.2k ages ago. If you can afford vx450- go for it. Or else cx400w for 3.2k.
Hardware BBQ |
#22 (permalink) |
GUys have got my new Rig now, on day before yesterday didnt had much time to sit on the new RIG ......
Phenom II 920 @ 2.8 Ghz Gigabyte MA78G-DS3H 2 GB OCZ RAM 800 Mhz Tagan 650 watts PSU Palit 4850 512 DDR3 Cooler Master Elite 334 cabinet 500 GB WD HDD thnks for all the suggestion guys....
#23 (permalink) |
Intel OCer
^You seem to be the first phenom 2 owner here...Why dont you post some benchmarks?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| system upgrade | vvikas28 | Hardware Q&A | 10 | 18-02-2009 08:40 PM |
| Need help to upgrade system | raj_82_18 | Hardware Q&A | 1 | 26-10-2007 08:49 PM |
| AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! | karthik316_1999 | Internet & WWW | 11 | 18-07-2006 08:10 PM |
| system upgrade | readermaniax | QnA (read only) | 14 | 01-08-2005 11:19 PM |
| system upgrade!!! | karthik316_2003 | QnA (read only) | 7 | 25-05-2005 02:01 AM |
