Old 02-02-2009, 09:42 AM   #1 (permalink)
naughty boy :) :)
mahesh's Avatar
Question Monitor in the range 8k-10k
Hi,
i wold like to buy a new LCD monitor. i am currently using a black colour 17 inch CRT monitor(samsung). how much will i get for this monitor? If i buy a 19 inch LCD monitor will my gfdx card supports this without any problem(i am having 8600 GT 512 DDR3)?
need ur opinions. one more thing, i am very tight in my budget. the range i mentioned is including the amount i get after selling the current monitor.
TIA
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 02-02-2009, 09:49 AM   #2 (permalink)
liNux+usER
Nuxer's Avatar
Default Re: Monitor in the range 8k-10k
Screen size of new monitor?
Nuxer is offline
Old 02-02-2009, 10:02 AM   #3 (permalink)
naughty boy :) :)
mahesh's Avatar
19 inch. will my gfx card support this monitor?
mahesh is offline
Old 02-02-2009, 10:07 AM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
ur gfx will support 19 inch monitor,u can go for Dell SE198WFP 19" for 9k
My Stomach pains
http://tinyurl.com/32jj4m
zyberboy is offline
Old 02-02-2009, 10:10 AM   #5 (permalink)
liNux+usER
Nuxer's Avatar
Yes, your graphics card is supported 19 inch monitor.
You can expect around 2K for your old monitor.
Samsung SyncMaster 933SN (8.75K)is my suggestion.
Nuxer is offline
Old 02-02-2009, 10:17 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Dell 198WFP or Samsung 943NWX. I prefer 198WFP. I have this and it rocks.
desiibond is offline
Old 02-02-2009, 10:48 AM   #7 (permalink)
naughty boy :) :)
mahesh's Avatar
Will it take more power than the 17 inch CRT monitor?
mahesh is offline
Old 02-02-2009, 11:13 AM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
nope!!!
Old 02-02-2009, 05:57 PM   #9 (permalink)
i have a viewsonic 19" ... personally i think its too big for gaming .. 9.8k when i bought it ... 2ms refresh rate ... gud enuf ...
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 (CM7 beta6.5), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur detailshere
k4ce is offline
Old 02-02-2009, 07:33 PM   #10 (permalink)
naughty boy :) :)
mahesh's Avatar
Is 198WFP and 1909W are same
mahesh is offline
Old 02-02-2009, 09:12 PM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ No. 1909, I think has 16:9 aspect ratio while 198WFP has 16:10 aspect ration. not sure though. just check the specifications for these.
Old 03-02-2009, 01:37 PM   #12 (permalink)
naughty boy :) :)
mahesh's Avatar
Dell monitors are not avilable in my city(i am from trivandrum, kerala). The available brands are ACER,LG,SamSung,Viewsonic and AOC. Among these which one i should have to buy? please help guys.
mahesh is offline
Old 03-02-2009, 02:42 PM   #13 (permalink)
damnbadman666
damngoodman999's Avatar
Samsung 19" mist model
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] MA790GP-UD4H OCZ DDR2 2x2GB Asus GTX 560ti 1TB SATA2 LG 20" LED Razer DA mice RED HOT cabby
damngoodman999 is offline
Old 03-02-2009, 02:44 PM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Samsung. No second thought (if Dell is not available).
Old 03-02-2009, 03:14 PM   #15 (permalink)
naughty boy :) :)
mahesh's Avatar
Can u specify the exact model number? Also whether it supports Dvi input.
Can u specify the exact model number? whether it supports Dvi input?
mahesh is offline
Old 03-02-2009, 08:49 PM   #16 (permalink)
liNux+usER
Nuxer's Avatar
Check Samsung site and choose your model
Samsung India
Nuxer is offline
Old 04-02-2009, 01:33 PM   #17 (permalink)
damnbadman666
Or else try VIEWSONIC 22" inch monitor for 10200/-
model = VX2240w
this is decent one
Old 04-02-2009, 05:57 PM   #18 (permalink)
naughty boy :) :)
mahesh's Avatar
Samsung 2033SW for 8850 here in trivandrum, kerala. Now i am planning to buy that. but for my old monitor the dealer told me that he can buy that for 1.5k. is that ok? i need ur opinions.
mahesh is offline
Old 05-02-2009, 04:06 PM   #19 (permalink)
liNux+usER
Nuxer's Avatar
When I replaced my old 15'' LCD monitor (3 years old) with a 19'' LCD, the dealer bought that for 4K.
Who is your dealer Logtech or Indicom?
Nuxer is offline
Old 06-02-2009, 10:22 AM   #20 (permalink)
naughty boy :) :)
mahesh's Avatar
That is a friend of my friend. Wen i asked logtech they say that they can give a max of 1.2k for that monitor. so i decided to give that to my friend's friend. but my monitor is CRT, not LCD.
mahesh is offline
Old 06-02-2009, 11:58 AM   #21 (permalink)
The Sorcerer's Avatar
Something needs to be corrected here. Samsung 943NWX has only analog connection. Technically you are flushing down the money for just keeping it on your table. Viewsonic has history of bad customer support. Best if you check out Samsung SyncMaster 2233sw. The monitor is a 21.5 inch 16:9 widescreen with 1920 x 1080 full HD resolution. The samsung 2233sw costs around 10k and its practically the same as e2200hd- atleast somewhat in technical specs. In other words you are getting more for less. Either this samsung's 22 inch or the dell 1909.
Hardware BBQ
The Sorcerer is offline
Old 06-02-2009, 03:57 PM   #22 (permalink)
naughty boy :) :)
mahesh's Avatar
i am going for samsung syncmaster 2033(20 inch) monitor
mahesh is offline
Old 06-02-2009, 05:20 PM   #23 (permalink)
check out the 22 inch ones I said. If you can get it, well and good. Make sure it has atleast a dvi port.
Hardware BBQ
Old 06-02-2009, 07:47 PM   #24 (permalink)
naughty boy :) :)
mahesh's Avatar
it has dvi port. y i am not going for 22'' inch is it will b difficult to play games using my gfx card. also my budget is very tight dude.
mahesh is offline
Old 06-02-2009, 08:00 PM   #25 (permalink)
liNux+usER
Nuxer's Avatar
Price?
Nuxer is offline
Old 06-02-2009, 08:10 PM   #26 (permalink)
Just an alternate. If you think you will go for better graphic in the future, 22 inch. But one can stick with 19-20 inch so go for it.
Hardware BBQ
Old 06-02-2009, 10:26 PM   #27 (permalink)
naughty boy :) :)
mahesh's Avatar
hai i just now got my monitor. its awsome yaar. need to check whether any problem in playing games(fifa 09 and COD4). cheers
mahesh is offline
Old 08-02-2009, 08:31 AM   #28 (permalink)
naughty boy :) :)
mahesh's Avatar
Price?
8850 here in trivandrum, kerala. But u have to buy the dvi cable seperately.
mahesh is offline
Old 08-02-2009, 06:44 PM   #29 (permalink)
Red face Re: Monitor in the range 8k-10k
Hello people..
I am in urgent need of a new monitor (LCD) because my old monitor (CRT) conked off.
I am looking for a low cost solution at present because I am not in a position to spend too much.
Any suggestions? I am looking for a 15" or 17" monitor...
Thanks,
-HK.
h_kunte is offline
Old 08-02-2009, 08:40 PM   #30 (permalink)
liNux+usER
Nuxer's Avatar
Shop name please.....
Nuxer is offline
Need HTPC configuration ! (Low range / Mid range) blackbird PC Components / Configurations 19 02-04-2009 04:36 PM
Best Lcd Monitor In 19" Range pvsraao Hardware Q&A 27 24-11-2007 11:40 AM
Monitor Frequency out of Range shakti Software Q&A 3 18-10-2007 10:21 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
