| Forum |
#1 (permalink) |
Half of the time, when I turn it on it boots properly and goes to windows. Infact on hitting the power 2nd or 3rd time it turns on. The othr part of the time, I turn it on and this happens: - The lights on the keyboard/front panel turn on - Hard drive and fan turns on - Nothing displays on the screen. The backlight doesn't even turn on. This happens indefinately until I hit the power button again and turn it off. IT happens regardless of being on AC power or battery. but i observe ts better luck wit adpter on. What could the problem be? I have a fair bit of diagnostic software I can run so if anyone has any recommendations for what I should use to diagnose the problem I'm all ears too. ps for reference m pasting a speedfan reading image of my system...looks fishy...plz refer ![]() Enjoy~!
No Pain...No Gain Last edited by speedyguy; 01-02-2009 at 05:50 PM. |
#2 (permalink) |
Laptoping
How old is the laptop? Try removing the battery and running it on AC directly. Or you can try to get hold of a different (working) power adapter. I think this is might be a power issue.
If you feel the laptop gets VERY hot even after a few mins of use, dissect the laptop to clean the vents and other internals.
You could think I'm wrong, but that's no reason to stop thinking. |
#3 (permalink) |
Wire muncher!
Since you've tried both AC as well as battery power, I don't think its an external power issue. Yes, internally there maybe a problem which the qualified professionals may be able to diagnose.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#4 (permalink) |
itsa a tablet pc hence a bit complicated to open up...will try my best....don wanna take it 2 hp....some very bad exprnces wit them....any cooling solution advisable?
ps: m not sure but i just feel that air is also not blowing properly from vents...can just feel some heat near to that... Enjoy~!
No Pain...No Gain |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Strange behaviour of two service providers | rajesh_nk22 | QnA (read only) | 3 | 19-08-2008 10:47 AM |
| Very Rude Behaviour: BSNL CC | Anindya | Chit-Chat | 30 | 09-12-2007 11:39 AM |
| Strange and stupid behaviour of appwiz.cpl [Add/Remove Programs] | rohan | Software Q&A | 2 | 16-07-2007 03:30 PM |
| Strange Behaviour of VCD......... | nitish_mythology | QnA (read only) | 19 | 03-01-2007 11:14 PM |
| UNUSUAL BEHAVIOUR!!!! | Deva | QnA (read only) | 18 | 05-03-2005 01:17 AM |
