| Forum |
#1 (permalink) |
AMD 790GX - gigabyte phenom x4 - 9950 black edition ati raedon HD4870 4 gb ram corsair 750watt power supply 500GB segate cooler master 590 , though this rig is for gaming .........even in 1024x768 resolution crysis gets stuck , and im experiencing the same problem in many games .....and my usb port sometimes works and sometimes it dosent ! the os never loads on the first try ...first the comp starts then the boot screen then just ends at a black screen , then when i restart again OS loads ! ! ! , im facing a lot of problems guys ! ! i need your help ! ! i would seriously appreciate your help ! ! and i also forgot to mention im presently using windows vista ultimate , and i also have XP professional , which has stoppd working altogether ! Last edited by quasta123; 01-02-2009 at 12:22 PM. Reason: Automerged Doublepost |
#4 (permalink) |
Fast 'N' Furious
Some 500GB seagate hdd has firmware probs so it could be due to firmware bug. update the firmware of your hdd.
Also update your mobos bios & every drivers including gfx card to the latest. Use vista with SP1. See if your cpu, gfx card & mobo overheats. BTW, who is the maker of your gfx card like palit, sapphire etc.
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
#5 (permalink) |
Democracy is a myth
Drop of frame rate and dragging Game is a sign that, "MAY BE" the power cable of ur grafix card is not connected.
Rest issues...may be due to infection in ur system. Which kinda security s/w do u use??
"My opinions may have changed, but not the fact that I am right." "I'm never wrong. Once I thought I was wrong, but I was wrong" |
#6 (permalink) |
King of my own Castle
As he already pointed out that He has reformated the system so Infection is out of question.
It has got to be hardware problem.Propably a loose Cable connection or Faulty PSU
Never take life seriously. Nobody gets out alive anyway. |
#7 (permalink) |
you might as well take everything apart and reassemble it slowly back again
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va |
#8 (permalink) |
EXIT: DATA Junkyard
1. Seagate HDD's r sucking rite now, huge issues.
2. Have u installed the latest graphics card drivers?
http://pleaseguide.me/ |
#9 (permalink) |
Fast 'N' Furious
I think Seagate has fixed their firmware bug on every 7200.11 series model & fixed
firmwares are ready for download.
#10 (permalink) |
EXIT: DATA Junkyard
Even the new firmware turned out to be sour afaik^
#11 (permalink) |
Democracy is a myth
Why not our OP replying??
Is his problem solved?
#12 (permalink) |
You have not mentioned about your CRT monitor or LCD. If everything is ok, Try 800X600 Resolution for gaming, may be possible that Graphics Card may not support those games at 1024X768. Please Mention Games next time if problems is not resolved.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
