Old 28-01-2009, 12:15 PM   #1 (permalink)
Default Which card is better choice on 350w psu
Hi , i would like to know which of these cards is better choice for 350w psu with amd 3200+ proc 2.2ghz
1. 8600gt
2.hd 4670
3.9600gso
4.9500gt.
also i dont want to upgrade the psu , please let me know which one of the cards will work properly on my system . i am confused between 4670 and 9600gso. if they are not compatible i will go for the 8600gt.
smoker999 is offline
Old 28-01-2009, 12:26 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Which card is better choice on 350w psu
maybe 8600GT.
if you are using 350W PSU from Corsair and Tagan, all four cards will work. For PSU's from iball/zeb/mercury, 8600gt and 9500gt may work
desiibond is offline
Old 28-01-2009, 02:09 PM   #3 (permalink)
i think its some local brand psu , as it is an assembled machine and quite old , i should go for 8600 gt as its cheaper and also i hv heard 9500gt is just 8600 will another name . Also can i run latest games smoothly on 8600 gt at med resolutions.?
Old 28-01-2009, 02:13 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
what is the size of your display? is it CRT or is it LCD?
Old 28-01-2009, 02:17 PM   #5 (permalink)
go for 9500 GT..its better than 8600.. it also consumes low power.
dips_view is offline
Old 28-01-2009, 02:18 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yep. 9500GT is more or less the same as 8600GT. But it is lot faster than the 8600GT.
reason is that it is build on a better fab and has superior architecture.
Old 28-01-2009, 03:36 PM   #7 (permalink)
hi what about the 4670 ati , i read it also uses less power .
Old 28-01-2009, 03:52 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
HD4670 takes 207 Watt under load and so, it's certainly not recommended.
I have HD2600XT (takes around 200W under load) and I had to get a 400W PSU to keep the system stable. My old 350W system used to give problems like some device (soundcard/HDD) stops working due to inadequate power.
AFAIK, 8600GT too takes 180-200W.
Old 28-01-2009, 09:52 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
HD 4670 Requires only 10-70W so I think HD 4670 will run just fine.
Check this guide for graphics card power consumption :
http://archive.atomicmpc.com.au/foru...s=2&c=7&t=9354
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 28-01-2009, 10:08 PM   #10 (permalink)
Bond, Desi Bond!
desiibond's Avatar
10-70W??? are you joking???
that page says that HD2600XT uses only 21W-28W-49W. That's totally untrue. I had to change my PSU to 400W as 350W PSU was not able to provide enough power.
Old 28-01-2009, 10:26 PM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
1st of all I'm not Joking. Looks like you just confisued things up.
One Question - Where from you learn that HD 4670 consumes 207W.
PCI-E slot can deliver only 75W max. If 4670 consumes 207W ! how can it run without a additional power adapter ??!!
Is it the the GFX card alone or the whole rig including mobo, cpu & other peripherals.
Take a look at here :
http://www.tomshardware.com/reviews/...er,2122-6.html
According to this Radeon HD 4670 (512 MB) consumes 14.0W in 2D mode & 56.9W in 3D mode.
Radeon HD 2600 XT (512 MB) uses 18.1 in 2D mode and 54.4W 3D mode.
As for his Rig assuming :
AMD 3200+ consumes 65W
Mobo Consumes 20W
HDD Consumes 15W
DVD Drive Consumes 10W
Rams ( 2 pcs ) consumes 6W
HD 4670 Consumes 70W
So the total consumption is 186W.
If a generic PSU can deliver atleast 65% of it's rated current it woul be 227.5W.
Now if the PSUs 12V rail has amp rating of 16A it would deliver 192W which is enough.
topgear is offline
Old 28-01-2009, 10:29 PM   #12 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
@desiibond
lol,some say 8600gt uses only 70w at load and some reviews as 170w as u said,gfx power usage tests r always confusing
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 28-01-2009, 10:34 PM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
Dude no gfx card without a addtional power adapter can consume more than what
PCI-E slot deliver which is 75W
topgear is offline
Old 28-01-2009, 10:47 PM   #14 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^lol u r correct,many sites show the total system power wen testing gfx card power usage, i got confused
zyberboy is offline
Old 28-01-2009, 10:59 PM   #15 (permalink)
Bond, Desi Bond!
desiibond's Avatar
hmm. that's a really valid point. think you are right and not joking
Old 29-01-2009, 09:35 PM   #16 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
He's rite, it's MAX TDP for HD4670 is 50W in real.
HD4650 is about 40-45W and that's y I suggest HD4650 for Rs. 4800.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 31-01-2009, 08:17 AM   #17 (permalink)
k thanks i ll go for the 4670
Old 31-01-2009, 01:27 PM   #18 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
No wait, go for the HD4650.
It now costs 4.4k, and it doesn't make sense to buy a 5% faster HD4670 for 5.5k.
About me:
Old 31-01-2009, 05:47 PM   #19 (permalink)
The Sorcerer's Avatar
Before we continue ahead- very few local psu run as what is mentioned in the psu specs. A 100w psu is badged as 400w, dont expect 350w or higher than 400w any different. efficiency, ripple and protection comes into place. Not that I am scaring the OP, but one should be cautious. More than half of the problem happens because of the power input- especially in India.
Goes without saying- desiibond first google then let us know if one is joking or not. No pun intended but there have been lot of incorrect info that you give to many.
Hardware BBQ
The Sorcerer is online now
Old 31-01-2009, 09:22 PM   #20 (permalink)
Fast 'N' Furious
topgear's Avatar
Thats really make sense.
But I thought 4670 is the only best performaning card compared to all gfx cards which doesn't need external power connector.
topgear is offline
Old 31-01-2009, 09:25 PM   #21 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
No, now HD4650 enters the arena too.
About me:
Old 31-01-2009, 09:32 PM   #22 (permalink)
Fast 'N' Furious
topgear's Avatar
See this review. I think 4670 is 10-15% more faster :
http://xtreview.com/addcomment-id-62...ce-review.html
topgear is offline
Old 01-02-2009, 01:24 PM   #23 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yes, but HD4670 price 5.5k, actually 5.8k, HD4650 4.4k, which one makes more sense?
BTW I saw Times Classifieds AD,
BenQ 22" FULL HD @ 11k
BenQ 19" FULL HD @ 7k
Check latest prices.
About me:
Old 01-02-2009, 08:46 PM   #24 (permalink)
Fast 'N' Furious
topgear's Avatar
Palit HD4670 512MB DDR3 super is only Rs. 5250
Palit HD 4650 512MB DDR3 Super is Rs. 4850
http://www.theitwares.com/gfxcards/gfxcards.htm
So I think it's better to get HD4670.
topgear is offline
Old 02-02-2009, 03:27 PM   #25 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Hd4650 Ddr3?
About me:
Old 02-02-2009, 10:03 PM   #26 (permalink)
Fast 'N' Furious
topgear's Avatar
Sorry, Thats not Palit HD4650 super.
It's palit HD4650 Sonic which comes with 512MB DDR3 Memory.
http://www.palit.biz/main/vgapro.php?id=978
topgear is offline
Old 03-02-2009, 09:41 PM   #27 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
But that does not make sense, u sure, HD4650 was supposed to be DDR2 only!
About me:
Old 03-02-2009, 09:57 PM   #28 (permalink)
Fast 'N' Furious
topgear's Avatar
Ya. I'm sure. Sapphire also has one HD4650 model with 512MB DDR3:
http://www.sapphiretech.com/us/produ...w.php?gpid=255
topgear is offline
Old 04-02-2009, 07:02 AM   #29 (permalink)
Revolution's Avatar
Question Re: Which card is better choice on 350w psu
Do you know the price and the availability of the card in Kolkata ?
Revolution is offline
Old 04-02-2009, 12:04 PM   #30 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Hmm, nice, HD4670 features in an HD4650.
That makes a costly HD4670 useless cuz HD4650 is Overclock able, a lot that too.
About me:
The choice of UPS Techie_Geek Hardware Q&A 4 22-01-2006 06:55 PM
Tell me the right choice h_kunte QnA (read only) 6 24-11-2005 06:50 PM
Is 350W SMPS enough for my Hardware component??? stalin QnA (read only) 10 08-05-2005 11:49 AM
It's a question of choice. DKant QnA (read only) 11 24-03-2005 01:08 AM
- by c4u
