Old 28-01-2009, 03:44 AM   #1 (permalink)
Default Computer lag while reading/writing from dvd-rw drive
my comp specs are as follows:
intel c2d e7200 processor
intel dg35 motherboard
1gb x2 ddr2 ram
nvidia 9500gt 512 mb
seagate 250gb sata hdd
wd 160gb usb hdd
sony dvd rw dru-v200a
whenever i read or write a dvd or cd my computer lags horribly.... even when no other processor is running.... it takes me 40 mins to burn a dvd or even a cd and i can barely open my computer..... i can't watch a movie off a dvd because it lags too much everytime i have to copy data from the dvds onto my comp and even that takes too much time..... i've asked around and each time i get the reply that i'm runnin in PIO mode and not DMA, but that is not an issue.... i really don't know what to do ..... someone please help me......
diablo5789 is offline
Old 28-01-2009, 07:20 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Computer lag while reading/writing from dvd-rw drive
Ya. Seems like you drive is runnig on PIO mode. Go to device manager & set it to DMA mode in IDE ATA/ATAPI section.
Another thing could be bad data cable or loose connection or even a bad data port on mobo. Try with a new cable on a new port.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 28-01-2009, 05:43 PM   #3 (permalink)
no all that is not an issue... i wrote that dma is on... cables are all fine.... would there be a problem due to any driver issues??? do i need some xtra drivers for it to run properly???
Old 28-01-2009, 09:15 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Windows auto detect & install DVD Writer driver. They just work fine for all the drives.
BTW, What software you use to burn DVDs & quote the version also. It could be some drivers conflicting with each other.
Use only a single stick of Ram & see what happens.
Remove & Reinsert your Rams Firmly.
Unistall all DVD writing software & Run some Registry cleaning Tool.
Uninstall your DVD Drive From Device Manager. Restart Comp.
Windows Will automatically Reinstall DVD drive driver.
Copy data from DVD drive to USB & see if it lags.
Use tools like Imgburn to write DVD.
Try some Linux Live CD & see if it takes Too long to boot.
All in all it seems like your DVD drive has some prob. I think you need a replacement for that drive
topgear is offline
Computer lag while reading/writing from dvd-rw drive diablo5789 Software Q&A 4 28-01-2009 10:54 PM
Samsung SH-W162Z not reading/writing anything! Games Goblin Hardware Q&A 10 29-05-2008 11:58 PM
no writing only reading undertakerthedead QnA (read only) 2 16-01-2008 10:40 AM
DVD-RW not reading/writing any disc pskunk Hardware Q&A 4 28-09-2007 12:54 PM
DVD-Writing/Reading Problems bizzare_blue QnA (read only) 5 14-06-2007 12:02 PM
- by c4u
