Old 27-01-2009, 10:38 AM   #1 (permalink)
Norms Buster
Unhappy Hard Disk Overheating
I'm having a Samsung SATA 80 GB Hard Disk running on an ASUS MB with an AMD Sempron 1.83 Ghz. I tested the temperature of the HD with softwares which supports S.M.A.R.T.
At the beginning the temperature is in the league of 36 degree celsius but after using some office apps or not too disk intensive apps, the temperature rises to about 52 degree celsius within an hour.
Is this because the HD is faulty ? The 2 fans inside the cabinet are working properly without any obstructions. The HD is 3 years old and very sparingly used.
I'm having another computer with almost identical config in the same room with a PATA HDD. There is no overheating problem with that HD.
Should I replace the HD ?
VexByte is offline
Old 27-01-2009, 11:06 AM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: Hard Disk Overheating
Use anyone of the utility mentioned in this post: http://mrintech.com/3-best-utilities...th-at-its-best - It will give you warning if there's any future Hard Drive Failure
Make sure Air-Flow is good, clean internal dirt and cable clutter. When you are working on office suits, exit all other softwares which are running in the memory/taskbar. See what happens....
- MrinTech :)
mrintech is offline
Old 27-01-2009, 11:33 AM   #3 (permalink)
Norms Buster
Red face Re: Hard Disk Overheating
I had visited your link before. Also used the same utility.
Air flow is not too bad, I assume.
Cleaned the internal dirt & there is no cable clutter.
VexByte is offline
Old 27-01-2009, 11:35 AM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Add another fan to da front of cabinet such that it will blow air directly to the HDD,it will solve the overheating problem.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 27-01-2009, 11:46 AM   #5 (permalink)
Norms Buster
Would you please explain how can I do it ?
And, will SATA drives more heat than IDE ?
VexByte is offline
Old 27-01-2009, 12:07 PM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
chk ur cabinet if fan mounting holes r there at the front by removing the side panel,if yes then its easy,buy a 80mm case fan.otherwise u will need to make a custom hdd cooler.
zyberboy is offline
Old 28-01-2009, 09:59 AM   #7 (permalink)
Norms Buster
So are you saying that it's solely because of the lack on ventilation, the HD is overheating ? And, not because of any HD problem ?
VexByte is offline
Old 28-01-2009, 11:52 AM   #8 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^yes,add a front fan hdd temp shud come down
zyberboy is offline
Old 28-01-2009, 10:06 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
Once I had this kind of prob. added a front 80mm fan ( rs. 40 ) & the problem vanished.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 29-01-2009, 10:43 AM   #10 (permalink)
Norms Buster
I kept the cabinet open and worked for less that 1 hour. But, even then the temp was 52 degree Celsius.
VexByte is offline
Old 29-01-2009, 10:52 AM   #11 (permalink)
Wise Old Mouse
mrintech's Avatar
Dude get an extra FAN
- MrinTech :)
mrintech is offline
Hard thinking about Hard Disk power_8383 QnA (read only) 10 25-03-2008 05:14 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
cant add second hard disk drvarunmehta QnA (read only) 5 10-03-2005 11:24 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by c4u
