Old 25-01-2009, 12:28 AM   #1 (permalink)
Default Ram Fix
i have P4 2.8 ... 512 Mb HDD, 8400GS pci X16... P915GAV
m in a new fix... Got a new 1 GB DDR RAM... if i use it alone it gives me 400 mhz speed... and if put it along with my 512 MB ram.. though it becoms 1.5 GB but runs at 333MHZ... so shd i run 1 gb at 400 mhz or 1.5 gb at 333??
And ll crysis run on it??
navisangha is offline
Old 25-01-2009, 07:20 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Ram Fix
333Mhz & 400Mhz don't have much performance difference. Your old ram is probably 333Mhz one so the new ram is running at 333mhz to maintain stability.
Use 1.5GB ram @ 333Mhz speed or else
if you can buy another 1 GB 400mhz module & run your sys with 2x 1GB 400mhz ram that will be the best
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 25-01-2009, 01:08 PM   #3 (permalink)
Query Killer!!!!!!
max_snyper's Avatar
Default Re: Ram Fix
^^+1
if u want more performance from ur system install 1gb x 2 memory so that u can get dual channel configuration its lot better when it comes to performance in games!!!
max_snyper is offline
Old 25-01-2009, 01:10 PM   #4 (permalink)
Default Re: Ram Fix
ok.. thanx.. ll try... so i shd go for 1.5 333MHZ?
Old 25-01-2009, 10:25 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Ram Fix
You can go for 1.2GB @ 333 Mhz.
But as I & max_snyper said :
It would be best to go for 2x 1GB mem modules in dual channel cxonfig.
You will get 15-30% more performance ( varies from apps to apps )
topgear is offline
- by c4u
