Old 23-01-2009, 05:29 PM   #1 (permalink)
Default PC not starting- Help Plz...
Hello Friendz,
My sys is:
C2D E8400, ASUS P5N-D(750i SLI), G. Skill 2*2 GB DDR2 800 CL4, WD 320 GB, EVGA 8800 GT SC, CM 600w Extreme power, Zebby PEACE.
Today after one week i hv started my pc bt it's not starting. I mean, green light on mobo is on, but when i press power button on chasis, nothing happens. I think smps is ok bcoz i hv checkd with other smps. When i saw system to one computer guy, he removed 20+4 pin cable frm mobo and put two ends of one u-pin into different pin on that cable and all the chasis fan started but processor fan not started. Then he told me that my mobo has gone.
Wat u guys think is the problem? How can i chk which component is faulty? Dont tell that chk with friend bcoz friend is havin amd system.
Plz help.....
Thanks
chokhu is offline
Old 24-01-2009, 07:55 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: PC not starting- Help Plz...
hmm. why don't you check take the mobo to ASUS RMA (support) center?? Looks like a problem with mobo only.
Also check if the chassis front side panel's connectors are properly connected to motherboard, esp. power and reset connectors.
desiibond is offline
starting vipulgupta Technology News 1 18-05-2008 10:18 AM
Ubuntu Not Starting..... aneek Open Source 4 11-09-2007 10:20 PM
New Pc Not Starting wizrulz Hardware Q&A 8 20-08-2006 08:52 AM
FAR CRY Starting Problem reddick Gamerz 12 20-01-2006 08:10 AM
XP not starting!!! kato Software Q&A 21 11-10-2005 05:54 PM
- by c4u
