Old 23-01-2009, 12:26 PM   #1 (permalink)
Default Problem in DVD writer
hi
i have a strange problem in my DVD writer for since three days.the problem is,
when i am burning the dvd,it will come to 99% and at last,there is a session called writing lead-out.After that,the error message displayed like that
Burning process failed.
what can i do?please help me.
thecreativeboy is offline
Old 23-01-2009, 12:44 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Problem in DVD writer
I need to knw a few things b4 i can advice u sumthing:
1.) Wich DVD WRiter u are using?
2.) Make sure wichever DVD WRiter u are using, the lens is clean from inside, u can buy a DVD Lens cleaner from the market for Rs.100/- or so..
3.) Wich type of Media are u trying to burn (DVD 4 GB or DVD 8GB) and hv u tried burning different media brands (Like cheap ones as well as trusted ones like Moser baer')
In any case, jus clean the lens of the DVD with a lens cleaner and see wat happens..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 26-01-2009, 07:07 PM   #3 (permalink)
my dvd wirter is sony.and i have tried the sony and also the cheapest dvd.and i have burned the dvd which having the capacity is 4 gb.and another one strange problem is when i write the cd it will work properly.
Old 26-01-2009, 09:25 PM   #4 (permalink)
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
DVD-Writer Problem!!!! DD3030 Hardware Q&A 12 28-03-2008 08:02 PM
DVD Writer Problem salil_belani Hardware Q&A 11 17-05-2007 04:34 PM
DVD Writer Problem vineetrocks2005 QnA (read only) 1 11-12-2006 12:53 PM
DVD Writer Problem sagargv QnA (read only) 1 20-08-2006 07:42 PM
DVD Writer Problem siddhesh QnA (read only) 12 13-11-2004 09:13 PM
- by c4u
