Old 21-01-2009, 04:55 PM   #1 (permalink)
Post Computer Not Booting
Me have 2.4ghz p4-processor with 845gvsr board ,
firstly me have display problem but it solved by my vendor
after recconnection system when me started comp it will start
and after some time goes in freezz condition , but now when i am
try to start it it just start with one blink of keyboard lights and
it not shows any screen on moniter , no beep sound comes frm RAM....its a any serious problm....
Please help me..............
sagarkolhe777 is offline
Old 21-01-2009, 06:23 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Computer Not Booting
It can be any problem.. like problem with RAM or motherboard or heating problem or anything. I will suggest you to take to any local hardware repair center.
ravi_9793 is offline
Old 21-01-2009, 08:40 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
jst try to reset u r BIOS
VarDOS is offline
Old 21-01-2009, 09:39 PM   #4 (permalink)
might as well try re seating your heatsink.
could be that its not making proper contact..
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
fuzzz is offline
Old 22-01-2009, 10:25 AM   #5 (permalink)
Post Re: Computer Not Booting
thax varad but how to reset my systems BIOS , and it is not a problem with CMOS Battery?? , Please Tell Me How much Cost To Be For Reset BIOS.
Old 22-01-2009, 10:40 AM   #6 (permalink)
The Sorcerer's Avatar
^^ What cost .
Switch off the system completly and pres the power button 3-4 times to drain any power on the system. Then remove the cmos battery are around 5 minutes, plug it back in and then power it on.
Once you manage to get the system up, google for orthos and download the software. run blend test for 3-4 hours and let us know if the blend test gives any error, freezes or restart the system. Do the following and let us know so we can continue further if required.
Hardware BBQ
The Sorcerer is online now
Old 22-01-2009, 04:51 PM   #7 (permalink)
Unhappy Re: Computer Not Booting
thanx
if I Remove CMOS Battery It Lose Its Contain i.e.Setting , then how to gt it.... when i place it again and (google for orthos and download the software) which soft...(run blend test what is its meaning me not getting that one.....) Please help me....
please reply ...
Old 23-01-2009, 08:01 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
When you place the cmos battery again the bios will loads it's default settings automatically.
But you have to enter the current date, 1st boot device setting maually.
Take out your Ram sticks. Remove the CMOS Battery. Re-insert the CMOS battery after 5 or 10 minutes. Reinsert your ram sticks firmly. Your system should boot.
Orthos stress or blending test will test your system ( mainly CPU and Ram ) for stability.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 24-01-2009, 11:00 AM   #9 (permalink)
Hello Dear ,
I Was Done As U Said , I remove CMOS Battery And Re-insert it But When I Start Comp. Again Same Prob. Occur Heatsinkfan of processor and SMPS Fan Run Normally without any screen on monitor(just like monitor is off), but green light of moniter blink continuosly,i was kept system run for upto half hr. to see that whether it is restarted automatically but it not restated...... my moniter is ok when i was unplugged it show me msg like 'no singnal' i.e.it is ok whats the prob. please help me .......
reply fast dear me wating....plz help guys...
Hi Guys Plz Help Me...............................
Plz.................For My - Comp Not Booting Prob
Last edited by sagarkolhe777; 24-01-2009 at 03:56 PM. Reason: Automerged Doublepost
Old 25-01-2009, 05:40 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
Have you remove the ram sticks & reinsert them properly. Dpo these :
1. Remove Ram stick from each slot.
2. Reinsert the ram sticks again firmly. ( if you have only try inserting it in different slot )
3. Try with another Ram stick.
BTW, How much ram do you have installed in your system.
Quote the capacity of every single stick of Ram.
topgear is offline
Old 26-01-2009, 02:24 PM   #11 (permalink)
In My System Only One RAM (Dynet D333) Is Installed,its of a 256MB And I Inserted it in another slot ,
by 2-3 times i insert RAM in different Slot ... But Yet System Not Started...
due Can be another problem... i was put thermal paste bet heatsink and cpu so there is no problem of heating..... i asked to another vendor it says it is a problem with KBC(key boared controller) but when cpu started keyboared light blink and off .
whats the problem..... plz reply...
Old 26-01-2009, 08:53 PM   #12 (permalink)
Fast 'N' Furious
topgear's Avatar
Can you try with another ram module ?
topgear is offline
COMPUTER FREEZES after booting ? raja2281 Hardware Q&A 7 23-05-2008 04:30 PM
Computer Not Booting Up! Demonkiller Hardware Q&A 9 16-12-2007 03:12 PM
My computer is not booting kishan Hardware Q&A 7 18-01-2007 05:03 AM
Computer hangs after booting Pravin Software Q&A 8 23-12-2006 10:49 AM
computer booting stops for 3 seconds bishnu_rath Software Q&A 4 06-03-2005 10:14 PM
- by c4u
