Old 21-01-2009, 10:12 AM   #1 (permalink)
ajooba215's Avatar
Default what happened to my lapp`s keyboard...???
my friend just borrowed my sony vaio couple of days ago...and i got it back 2day..so when i tried to type some words...the keys weren`t working properly....'5' is written when i press 'i'...similarly some other keys are malfunctioning too, typing the numbers instead of their alloted alphabets...(... what can be the prob???
Y FOLLOW WHEN YOU CAN LEAD.....
ajooba215 is offline
Old 21-01-2009, 10:28 AM   #2 (permalink)
Control Of Chaos
connexion's Avatar
Default Re: what happened to my lapp`s keyboard...???
first of all u should ask ur friend himself(or herself) about wat happend. A similar thing had happened with my dell. the problem was water had fallen on the keyboard. after the support it was perfect so check for these things.
Remember noone says "its just a game" when they are winning.
http://in.youtube.com/djconnexion77
didn't watch it??? u r missin somethin
connexion is offline
Old 21-01-2009, 10:51 AM   #3 (permalink)
Laptoping
Sourabh's Avatar
It's just that the numpad on the laptop keyboard is turned on. Find the right FN + key combo to disable it and it will be back to normal. There should be a Num Lock status light on the laptop like on a regular keyboard to check its status.
Sourabh is offline
What happened? pragith.net Chit-Chat 5 15-11-2007 10:27 PM
What has happened to the HDD?? khattam_ Hardware Q&A 12 01-10-2007 05:06 PM
Wat happened to the HDD...? Manshahia Hardware Q&A 10 07-07-2007 10:47 AM
how this happened the.kaushik QnA (read only) 5 02-09-2006 11:57 PM
Wat Happened ???? nipun_the_gr8 QnA (read only) 18 14-08-2004 11:32 PM
- by c4u
