Old 20-01-2009, 03:43 PM   #1 (permalink)
Default confusion of CPU and Mobo
I want to buy a quad core CPU. I'm confused between Q6600 and Q8200. Which one is good one?? Also suggest me a good motherboard for this CPU. I'm looking for
1. Asus P5Q Pro
2. MSI P45 Neo-3-FR
3. Gigabyte GA-EP45UD3R.
parimal is offline
Old 20-01-2009, 05:47 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: confusion of CPU and Mobo
get Q8200 its 45nm compared to Q6600 65nm so it runs cooler and more energy efficient and overclocks more.
For mobo get P5Q-pro or gigabyte both are good.
My site: collegeclassroom.org
amitash is offline
Old 20-01-2009, 07:00 PM   #3 (permalink)
Yeah but since Q6600 has more cache, I'm more towards it. Any other inputs??
parimal is offline
Old 20-01-2009, 07:30 PM   #4 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
if it is really necessary then go with Q6600
cuz i would suggest q8200 as it is more energy efficient.runs cooler
what will be your primary usage of the cpu?are you going to OC/extreme OC?
for mobo i'd suggest MSI.
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 20-01-2009, 07:44 PM   #5 (permalink)
well the Q8200 is a good proccy i am currently using it. got it overclocked to 3ghz no sweat on value ram. im sure i can push it further soon as i get a good cooler and better ram .
the advantage of Q6600 is that it has more amount of cache and ppl have easily hit about 3.6ghz on it.
but Q8200 is 45nm compared to Q6600 which is 65nm. so more cooler and lesser power conspumtion.
as for the mobo, MSI p45 platinum is a good board. im using it myself
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
fuzzz is offline
Old 21-01-2009, 07:14 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
Get q8200 & Asus P5Q Pro
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 25-01-2009, 02:43 AM   #7 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Go with Q6600 having G0 stepping/revision - 8MB cache - a noob can also overclock it to 3.2Ghz - high top locked multiplier of 9 (dunno about q8200).
Will run a little hot than Q8200 - but that's not significant upto 3ghz.
But 8MB of cache gives q6600 some edge over Q8200!
Both of them some plus and some minus.
It depends on how u use it!
MOBO HAS TO BE P5Q-PRO!
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Confusion......... ankitbh_cool Software Q&A 20 10-10-2008 10:48 PM
HELP-BiG CONFUSION CPU+MOBO Orionz CPU / Motherboards 3 27-11-2007 06:24 PM
SATA RAID Confusion and Optical Drive Confusion bbalegere QnA (read only) 2 20-05-2007 07:00 PM
AGP Vs VGA confusion???? taken QnA (read only) 1 11-04-2005 07:30 PM
Little confusion anurag_online QnA (read only) 5 19-02-2005 11:23 PM
- by c4u
