I have following Gigabyte MotherBoard :-
http://www.giga-byte.com/Products/Mo...me=8I845GVM-RZ
Gigabyte
8I845GVM-RZ
All the details of motherboard is in the above link. I copied the Memory part of my motherboard specification as below
Memory
- Type: DDR333/266
- 2 x DIMM
- Max capacity: Up to 2 GB (Max 1 GB per slot)
But the disappointing part is that...when I searched market here in NP, New Delhi..No one is selling DDR 333Mhz RAM
..they all saying now is the age of DDR3 RAM...
Only RAM available is DDR 400Mhz...some seller say it will be compliant with your motherboard, some says No it won't ...other seller saying...they can't say anything on this.
Currently installed RAM in my system is-- Slot 1 -- 128MB DDR 266Mhz -- Hyundai
Slot 2 -- 256MB DDR 266MHz --Simmitronics
But I want to upgrade to 1GB atleast.... but don't know wat to do
As DDR 333Mhz is not available....pls help me ...wat will i do....Do I install the DDR 400Mhz RAM which is available....as some sellers says it will run in ur system wid 333MHz speed....I m not clear wat to do???
....pls help me guys...
Also ...sellers only talk abt RAM capacity(512MB, 1GB etc.), type(DDR, DDR2 etc) and speed(400Mhz, 800Mhz etc.) but no1 talk abt other attributes of RAM...as I found from my motherboard specification that only 184pin DIMM, unbuffered, unregistered, non ECC, single channel DDR 266/333Mhz RAM is supported with.....even if assuming that DDR 400MHz can run on my motherboard....don't I have to look for these other attributes also???
...coz no seller is telling anything abt theses??? pls help me ...
Thanks in advance & waiting for ur helpful replies
