Old 17-01-2009, 02:01 PM   #1 (permalink)
Default ram suggestions
i have 2 x 1GB transcend ram in my current system
but from the looks of it, its just not going to cut it for overclocking.
so i was thinking of buying some new ram for my system
please suggest good ram that i can buy which will be good when it comes to overclocking and still not be insanely expensive
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
fuzzz is offline
Old 17-01-2009, 04:41 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: ram suggestions
I would say Corsair 2x1gb ddr2 800MHz performance kit for 2.5k
desiibond is offline
Old 19-01-2009, 02:12 PM   #3 (permalink)
ionicsachin's Avatar
Try G.Skill 2x1GB DDR2 800MHz RAMs, known for their good overclockability
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 19-01-2009, 07:17 PM   #4 (permalink)
umm thanks for the suggestions guys..
but there are loads of rams with the company you suggested.
could you please be more specific as to the model no or code no or something?
My lappy
Acer 5930 G
fuzzz is offline
Old 19-01-2009, 07:35 PM   #5 (permalink)
The model which i suggested is G.Skill F2 6400CL5D 2GBNQ
Here is a highly detailed overclocking report of these sticks
http://www.xtremesystems.org/forums/...d.php?t=135578
My first song
Old 23-01-2009, 12:08 PM   #6 (permalink)
ionic. from the looks of the article, those modules seem rather expensive. close to 9k for 2 gb
could you perhaps suggest something a tad bit cheaper? lol
also those particular modules are not available here..
My lappy
Acer 5930 G
fuzzz is offline
Old 23-01-2009, 12:59 PM   #7 (permalink)
No man, this article was posted in Feb 2007, at that time these babes were costly...I bought them from lynx-india last april for some 2300 bucks, and they are super good rams..
My first song
Old 23-01-2009, 04:27 PM   #8 (permalink)
okies i have been searching all over the net related to ram ..
and seems that D9 chips in ram as considered to be the best.
i very much doubt that any of the hardware vendors will even know that.. unfortunately the only way to know is to remove the heat spreader and if i were to do that the vendor would mostlikely chew me alive
any1 know of any place in mumbai that sells crucial ram ?
cause they have only D9 chips in them ..
btw sachin.. that ram aint available any more
My lappy
Acer 5930 G
fuzzz is offline
Old 23-01-2009, 06:20 PM   #9 (permalink)
ohh tats sad man, they are really good ones..
My first song
Need Some Suggestions !!!!!!!!!!! hayabusa_ryu Reviews 1 15-11-2007 10:16 AM
any suggestions alexsylvester07 Gamerz 1 06-04-2007 11:06 PM
Suggestions for a new PC Yamaraj QnA (read only) 16 25-05-2005 06:35 PM
any suggestions????? mylifevp QnA (read only) 3 28-12-2004 08:15 AM
- by c4u
