17-01-2009, 09:42 AM
wid million core procesor
Need Your Help Guys!!!!!!!!!
I need to change my mobo and my budget is Rs.3500.
I want a gaming mobo so if i go for
MSI P6N GM-L NVIDIAŽ MCP73V Chipset 1333 FSB
or
Asus P5N MX Nvidia GeForce 7050 1333 FSBwith 4 GBs of ram will i be able to Play NFS Undercover without installing a graphics card?If you have a better mobo on mind at dis price range for this purpose then pls help me out.I require your help urgently.
Btw my procy is C2D 1.8 Ghz so hope it gonna work fine wid da mobo.
Thanx in advance.
Intel C2D E4300|4GB DDR2 800 RAM|1.5 TB HDD|Nvidia GeForce 9500GT 512MB DDR3|
17-01-2009, 10:38 AM
In the books..Studying
Re: Need Your Help Guys!!!!!!!!!
At lowest config of game ...It must be able to run...
17-01-2009, 10:48 AM
damnbadman666
the game can run run only @ low performance . Changing the mobo will not improve the gaming performance
17-01-2009, 11:13 AM
EXIT: DATA Junkyard
or
Thanx in advance.
Save up about 5k, get a G31 for 2.2k and an HD4550(better than 9500GT) for 2.8-3.8k AFAIK.
19-01-2009, 01:21 PM
Is G31 better dan NVIDIAŽ MCP73V?
and shall i go for MSI HD 4350 or XFX 8600GT (both 512mb ddr3 though MSI is much cheaper)?or pls suggest a good gcard around 3500-3700.
19-01-2009, 01:45 PM
M3TAL H3AD M3
Better go with G35 motherboards. They are great VFM.
I spit Rainbows.
19-01-2009, 01:56 PM
wats da cost of G35.I can max afford 2.5k as am planning 2 buy a gcard.one more thing should i go for xfx 8600 one or same priced HD series?
19-01-2009, 02:11 PM
Friend, adding more of RAM will improve performance like lesser loading times and no stucking in the gameplay to some extent, but the main thing thats required for gaming is Graphic Card, unless you have a good one you cant play games at good looking glory
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
19-01-2009, 09:33 PM
EXIT: DATA Junkyard
Get G31, has dual channel ram support, tht's y suggesting it.
And both gfx r sucks anyways, G31 or G35,so best low costing G31
20-01-2009, 10:57 AM
Fast 'N' Furious
Ya. Get G31 based Asus P5KPL-CM Rs. 2300.
And HD4550 ( is it available in here ? )
20-01-2009, 10:59 PM
Ok am confused. Which is a better combination
a) MSI G31 M3F and XFX 8600GT
b) MSI G31 M3F and MSI HD4350
c) MSI P6N GM-L and XFX 8600GT
d) MSI P6N GM-L and MSI HD4350
or is there any other better combination?I mean is HD4350 better than 8600GT or not?
21-01-2009, 06:20 AM
Fast 'N' Furious
Why aren't you interested in asus boards ? And is there any problem not geting 9500GT.
Go for Asus P5KPL-CM ( Rs.2350 ) and Palit or Sparkle 9500GT ( Rs. 3500-4000 )
21-01-2009, 08:13 PM
EXIT: DATA Junkyard
9500GT costs more but performs almost same to same with HD4550, prob is I dunno one shop which has HD4550 yet.
BTW-I updated "Latest Prices", havn't added P2 prices or HD4550/4350, no confirmation on their prices yet.
21-01-2009, 08:23 PM
Wait before you jump to a conclusion to buy a mobo + graphics card better tell what is your current mobo and if it has a PICe x16 slot then go for a better graphics card that will also ensure that you can play most if not all games
So please post your current config with PSU and the budget you are ready to spend altogether and the possible recommendations will be given!
21-01-2009, 11:16 PM
My current mobo is asrock 775i n it doesnt hav a pci slot only agp so i want 2 change it. so pls sugeest me which combi to go wid?btw which mobo is better msi or asus?
n wat about Palit 9400GT Super 1GB DDR2 - Superis it better than Hd4350?it costs just 3250bucks
21-01-2009, 11:53 PM
dá ûnręäl Kiņg
buy a overclocking friendly motherboard so u can overclock ur C2D
My Stomach pains:D:D
http://tinyurl.com/32jj4m
22-01-2009, 06:22 AM
Fast 'N' Furious
Biostar has a P35 mobo priced only Rs. 3500 or so ( lynx-india ) but I don't know it it's available in kolkata - Last time I checked I could not find one.
Asus & MSI both are good but I prefer asus. Don't even think of 9400GT - This card/GPU just sucks. Instead try getting a 9500GT. It's far more better than 9400/HD4350.
22-01-2009, 04:09 PM
Ok Thanks guys am going for ZoTac ZT-95TEH2P-FSL 9500GT 512MB DDR2 and which mobo should i buy MSI P6N GM-L or G31 M3F.
will P6N having nvidia chipset give me an extra edge in perfoemance during gaming?
23-01-2009, 06:50 AM
#19 (permalink)
Fast 'N' Furious
Go for Asus P5KPL-CM. It's based on intel G31 chip & is better than both MSI P6N GM-L & G31 M3F.
P6N doesn't even supports dual channel. So memory performance in gaming will reduce by 15-30%.
23-01-2009, 11:40 AM
#20 (permalink)
Thanx topgear am going for ZoTac ZT-95TEH2P-FSL 9500GT 512MB DDR2 and Asus P5KPL-CM.
Btw can HD 4350 outperform 9500GT because it is DDR3 while 9500GT is DDR2?Reply ASAP cuz am buying it tomorrow morning.One more thing where in chadni (kolkata) will i find the best deal,Technocrat or Supreme?and will the price be more or less same as theitwares.com?
oh 1 more thing I have 3 IDE devices(dvd writer, dvd rom n hdd) from my old sys which i want 2 connect to my new sys so if there is a shortage of ide ports what should i do.(i dont want to throw them away)
Reason: Automerged Doublepost
23-01-2009, 08:38 PM
#21 (permalink)
EXIT: DATA Junkyard
Yup go for that, best in the range.
23-01-2009, 10:07 PM
#22 (permalink)
Fast 'N' Furious
4350 GPU is not just powerful enough to outperform 9500GT. So stick with it.
If you want best deal avoid those shops. Try shops like vedat, mohit, M.D computers etc.
That mobo has only one IDE port ( actually most of the current mobo has the same )
so you can use the HDD and the DVD RW.
23-01-2009, 10:16 PM
#23 (permalink)
can u pls giv me the direction to these shops?thanx a lot man.u rock
btw wat abt eastern logica
24-01-2009, 10:11 PM
#24 (permalink)
EXIT: DATA Junkyard
^^U can order online
25-01-2009, 05:37 AM
#25 (permalink)
Fast 'N' Furious
Ya. eastern logica is not a bad shop but the prices are a bit higher there.
You can try computer world ( go straight ahead from eastern logica and you will find that on left hand side )
First of all I think it will be bit harder to find Zotac 9500GT card model which
is selling for Rs. 3250 in the itwares.
You will find sparkle, palit readily available. I got quote of Rs. 4000
for Palit 9500GT 256MB DDR3 ( gfx card which is better than DDR2 based 9500GT cards. )
Sparkle is selling for Rs. 3550 for 9500GT 512MB DDR2.
Mohit, Arihant is near Sabiir Hotel. Actually you will find many small & mid size shops there. Vedant is near also. Just try those small shops & you will get the best deal.
M.D. computer is near Exide Battery Shop. ( which is near eastern logica )
25-01-2009, 02:14 PM
#26 (permalink)
25-01-2009, 03:54 PM
#27 (permalink)
Good discussion this helps me too to recommend the config to my friend.
25-01-2009, 10:22 PM
#28 (permalink)
Fast 'N' Furious
Enjoy gaming & don't forget to try the STALKER Clear SKY also
BTW, How much you spend to buy that Sparkle 9500GT. Is it 512MB DDR2 based. Does it comes with active cooling ie with fan.
27-01-2009, 10:04 PM
#29 (permalink)
Thanks man i will surely try stalker cs.btw the sparkle gpu does hav a fan,its 512 ddr2 n it set me back by 3800bucks.thanks a lot again.btw is there any pc version of gran tourismo 5 (ps3 title)?i really liked the review.
28-01-2009, 05:45 AM
#30 (permalink)
Fast 'N' Furious
Thanks for confirming.
No it's only available for PS3
