Old 16-01-2009, 09:36 AM   #1 (permalink)
Default ac97 not detected
hi people, am new to this, let me start. i have an old system(intel p4 1.7 128 sdram, pci vga card, onboard ac97 & pci creative sound card). 1st of all onbord ac97 not detected and i hear many noises(only) from onbord sound. on the other hand my creative is getting detected as mm sound controler in dev. manager, but the driver setup says ther is no sound card, tried to D/L new driver but same result. the pci slots are fine (tested with vga card). so pls give me a solution as i tried evrithing else, thankyou
arungn is offline
Old 17-01-2009, 07:13 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: ac97 not detected
Try to insert that sound card on a different pci slot.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 17-01-2009, 11:41 AM   #3 (permalink)
Always Fresh!
shri's Avatar
Is there any setting in the BIOS to enable/disable onboard sound?
BE YOURSELF :)
http://everythingoutthere.co.cc
shri is offline
Old 17-01-2009, 09:24 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Ya. There is a setting in every bios to disable onboard sound.
topgear is offline
Old 19-01-2009, 10:00 PM   #5 (permalink)
thanx for responding, well the mbord is toast. so no more q&a
arungn is offline
IDE HDD not detected bnaresh84 Hardware Q&A 2 06-08-2008 08:11 PM
mic not working with ac97 sound card *GandaBerunda* Hardware Q&A 1 06-09-2007 09:12 PM
How can i change Line-in to Line-Out in mY AC97 Sound card? sushantvirdi Hardware Q&A 2 06-04-2007 10:56 AM
AC97 Integrated Sound Card Issues in Vista RTM sinstoic Software Q&A 2 03-12-2006 04:26 PM
Win XP drivers for Intel 82801 AC97 Audio Controller manas Software Q&A 8 27-02-2006 10:21 PM
- by c4u
