Old 16-01-2009, 02:33 AM   #1 (permalink)
Default Over clocking questions
ok so im new to overclocking.
i am running a Q8200 at 2.8Ghz from 2.33Ghz
motherboard is msi p45 platinum
i currently have 2*1 GB DDR2 800mhz transcend ram
now here is the setup
i am running at a mem divider of 1:1
so the fsb is set at 400 x 7 = 2.8ghz
rams running at 800mhz
i want to get some more juice out of the system. i want to get it up to atleast 3Ghz
till now 2 things were limiting me
1. the motherboard .supposedly supports only 1600fsb. this has been fixed(supposedly) with a bios update. but yet to be tested
2. the rams. the rams are already running at their maximum rated frequency of 800Mhz
what i would like to know is, would i be able to raise the freq of the ram some more to say 900mhz ? by applying additional voltage?
cause if i can then i would be able to achieve about 3.1Ghz
also any advice u would like to give me regarding anything i should keep in mind while overclocking ... fire away (this is my first time overclocking)
Q8200 @2.8Ghz,MSI p45 plat,2*1GB transcend DDR2 ram,Xfx 8800gt, 160+640 GB storage
My lappy
Acer 5930 G
c2d p8400 2.26, 4 Gb DDR2 ram,Nvidia 9600 gt (512 - gddr3),250Gb Hdd.
fuzzz is offline
Old 16-01-2009, 07:13 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Over clocking questions
Search forum before you post.
You can push that q8200 to 3GHz. Set the fsb to 440.
So it would be be 440*7 = 3080Mhz or 3GHZ~.
Set mem divider of 1:1. So your Ram will be running @ 880 Mhz. This is 10% OC of your ram & it's quiet safe. Generally you don't need to increase voltage for this 10% mem OC.
If you have stability prob increase mem voltage to 1.85,1.9,1.95 ( I think it's the safe limit for value rams - If you're using those )
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 16-01-2009, 11:14 AM   #3 (permalink)
Intel OCer
amitash's Avatar
Which cooler are you using? Quads can get mighty hot so check load temps frequently
My site: collegeclassroom.org
amitash is offline
Old 16-01-2009, 07:19 PM   #4 (permalink)
errm topgear
thanks for the suggestions. srry my bad i didnt search :s
amitash
im using a cooler master hyper 212
load temp was going to 68 on prime. i have to go and get up arctic silver 5 tom currently using the thermal paste provided with the cooler by cooler master
btw after i have updated the bios last night, my previous overclocking setting were destroyed.
and now for some reason i am not able to get those setting to work.
i tried keeping the same voltage 1.18 even bumped it as much as 1.23v but what happens is the computer starts up. i can see the msi logo. and the part where in the windows os selection comes up the screen just remains blank. the computer doesnt even restart . help please?
currently im running on stock settings.
here is what i tried
fsb 400 x 7
mem divider 1:1
i tried the following voltage variations with the overclock
voltage to cpu from 1.17 to 1.23 -> my previous overclock was stable at 1.18v
also tried to increase the voltage of the ram up to 1.9
but either the computer just doesn't start up or gets stuck after i see the msi screen and then nothing
HELP
My lappy
Acer 5930 G
fuzzz is offline
Old 17-01-2009, 06:43 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Your CPU temps seem to be very high. Get good aftermarket cooler like Thermalright Ultra 120 Extreme with artic MX or silver.
You have to feed more voltage to your cpu. Set the mem voltage to 1.9v.
Set the cpu voltage to 1.3 or 1.35 & tell us what happens.
topgear is offline
Old 17-01-2009, 11:12 AM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Jus be careful with the voltage, dun exceed 1.35 for heaven's sake widout a very good air cooler as suggested.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 17-01-2009, 11:58 AM   #7 (permalink)
well i reflashed to an older bios, here are the settings i am running at.
the computer is under 100% load prime running for about 5 hours have a look see at the temps
My lappy
Acer 5930 G
fuzzz is offline
Old 17-01-2009, 08:02 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Very good, now hit 3GHz, let it be there.
Or u can buy a good air cooler for 2k and then hit 3.4Ghz widout any worries.
About me:
Old 17-01-2009, 09:21 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
67C is still a very high temp. The temp should not cross 60C.
Get some 3rd party CPU cooler with some good paste.
Increase cpu voltage to .5V increment like 1.2,1.25,1.3 and 1.35.
Increase speed to 3.0 & 3.4 repectively.
Do remember that in 486 fsb ( 3.4 Ghz cpu speed ) your rams will be running at 972Mhz speed ( 1:1 ratio ). At that speed your ram chip may require more than 2V So I think 3Ghz ( 440Mhz Fsb ) is a safe limit for your rams (880Mhz ) untill you upgrade to 1066Mhz Ram.
topgear is offline
Old 19-01-2009, 09:28 PM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^Unless he has good ram like with powerchips.
Hey OP, does ur transcend ram have powerchips?
About me:
over clocking/Latency rohitshubham QnA (read only) 3 22-08-2008 11:15 AM
Over Clocking help codename_romeo Hardware Q&A 13 27-11-2006 07:51 PM
Is over clocking safe? speedyguy Hardware Q&A 18 30-01-2006 02:04 PM
Help with Over Clocking! Plz.. Satissh S QnA (read only) 8 09-08-2005 11:58 PM
How Is it Clocking! damnthenet QnA (read only) 1 14-05-2005 02:57 PM
- by c4u
