Old 13-01-2009, 02:14 PM   #1 (permalink)
Default convert dynamic volume to basic volume
recently i bought a wd320gb hdd.as this was the first time that i was using 2 hdds, i didn't know much about configuring the new disk so i simply created 2 partitions on this new drive one 40gb and another 260gb.now when try to install win7 beta on the new 40gb partition, it says that it's a dynamic volume and os can't b installed in a dynamic volume. is there any way to convert dynamic volume to basic volume? i dont want to lose the data on 260 gb partition.
plz help!!
"Creativity is all about hiding your sources"
IITian is offline
Old 13-01-2009, 05:08 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: convert dynamic volume to basic volume
I do not think there is a way
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
No volume control ! ! ! ax3 QnA (read only) 16 06-06-2008 03:56 AM
normalise volume ismart QnA (read only) 5 26-09-2007 02:14 PM
low DVD volume Gaurav Software Q&A 5 03-03-2007 10:33 PM
MIC IN recording volume low jenaguru QnA (read only) 2 10-10-2006 10:04 PM
volume boost? rentacoder QnA (read only) 6 22-12-2005 12:25 AM
- by c4u
