hi all
last sunday i had a problem in my desktop,it suddenly shutdown when i tried to run any anti virus say avast home is loaded ,then config is ,p4intel 3.0 ghz dual core
1 gb stick and 256 mb stick of simmtronics, mother board is intel d915gag, and power supply is oddessey 450 watt,
i ran successfully the mostwanted and igi and also the action cube and have been running the same since last mnth easily .
when i opened the case i found dat cpu fan was just working as a slow fan
then the system shut itself down after, that it showed system was shut down due to overheating of cpu?
when the engg chkd he said everything is fine? plz get em what's the problem? and msg me plz as a human gesture
