Old 08-01-2009, 09:08 PM   #1 (permalink)
Question Help me find a good motherboard..??
Hi,,
I need to run Intel Dual Core D925@3.0Ghz...It is a LGA 775 socket..
Plz suggest any good motherboard with or without onboard Graphic Memory..
It should have support for 1336 Mhz system bus and support for 800Mhz ram..
Budget is AROUND Rs 3500...
Thnks..
Adit..
adit_3250 is offline
Old 08-01-2009, 09:23 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Help me find a good motherboard..??
Palit P35A I think is a good board. not suer if this one has onboard graphics or not
also check XFX 630i
desiibond is offline
- by c4u
