Old 08-01-2009, 04:01 PM   #1 (permalink)
kantiman's Avatar
Default Buying Benq E2200HD
Hello I am going to purchase a 22" lcd monitor
I have decided on Benq E2200HD for 12.5k. dell and samsung are not available.
I have C2D 6750 and 8800GT graphics card. the native resolution is 1920x1080.
but for gaming I have to go for lower resolution. at what resolution will I be able to play latest games.
what about 1280x720 or 1280x1024 resolution for gaming.
will there be black bands of any sort on monitor while playing at above resolutions. I have read on some forums that @ above resolutions the image looks either stretched or with black bands on all the sides.
kantiman is offline
Old 09-01-2009, 10:53 AM   #2 (permalink)
Default Re: Buying Benq E2200HD
IF you set the graphic card driver to fit the image then u will see that stretching effect.
If its off then there wont be stretching but u will see black bands on 2 sides which is normal.
ranjan2001 is offline
Lg or benq? mandar5 QnA (read only) 3 06-01-2009 07:01 PM
Benq E2200HD 21.5inch Full HD - Is it available yet ? zatang Gamerz 9 16-11-2008 03:29 PM
BenQ 1650 or BenQ 1670 Chirag Hardware Q&A 6 17-11-2006 12:51 PM
benq scanner naveenpoddar Peripherals 1 26-11-2005 04:30 PM
- by c4u
