well i bought a new mother board and processor
motherboard MSI p45 Platinum
processor Q8200
now when i run speed fan ,core temp,everest (ultimate edn) i am getting temperature readings of 60+ C on idle. (also core temp detects my cpu as Q9series.)
however the msi utility that came along with the board shows me temperature reading of about 30-34
im confused.. which is the correct reading
also i overclocked the processor from 2.33 to 2.8ghz
running prime the load temp is hovering around 60-65 is this ok ? im using an after market cooler from cooler master\
oh 1 more thing, in the bios it show the temps coinciding with the msi utility
i also tried truetemp .. it gives the same results as all the other utilites
