Hi,,,
i tried overclocking my PC''s RAM by reducingthe latencies..After restarting the PC,,i am getting nothing but three beeps like..teeet teet teeet...
There is no display And BIOS is also not appearing...I tried replacing the CMOS battery but dat dint solve the problem...Is it dat my motherboard has got any problem or wot...????
Its an intel D 945Gc motherboard...
Plz help ASAP..
Thanks,,,
Adit...
check your motherboard manual (search on intel site if you dont have it) and follow instructions as to the reset of BIOS settings using jumpers or someother methods
u did same as me....my RAM latencies were 5-5-5-15 and i changed it to 4-4-4-12 and the same condition occured as u r s....I tried to reset the BIOS but it didn't worked ...If u do the same as me u r prob can be solved visit Dead BIOS
But if u r doing it frst time don't do it...Do it on u r own risk....or just give the CPU to the vendor....
i think for secure side read ur motherboard manual as there is option of resetting the bios to factory default by changing the jumper positon on the board
First try the first image method if it works its good other wise try the second image method. Other wise try Varad Dilip Choudhari method but do it with great care
1
