Old 07-01-2009, 04:47 PM   #1 (permalink)
super jango's Avatar
Default Mouse single-click problem
Guyz,
My mouse started acting in a very unexpected way.It automatically changes my single-clicks to double-clicks!So when i am trying to do something using a single click like dragging an icon in the desktop, it suddenly opens the folder like when we press the double-click!I tried slowing the double-click speed in the mouse properties still the problem exists and the drivers are too working fine...................is the problem with my mouse?should I change it?Help me!!
super jango is offline
Old 07-01-2009, 05:54 PM   #2 (permalink)
Default Re: Mouse single-click problem
it is a problem with the mouse..they dont last with extensive use.. m not sure about the more expensive one though...but cheap mouse from logitech/microsoft also do not last...
well there is a solution if you dont want to spend money on a new mouse..even though a new one doesnt cost much..
unscrew the mouse..
use soldering pipe to remove the boxa which can be clicked with respect to the mouse button in question...
if you have a spare dead mouse..then you can use the boxa with click button from the dead mouse and solder it in the place you removed the faulty boxa from.
if you dont have a spare mouse then you could use the boxa from the mousewheel..exchange the two boxa..
well these thingy cost very less..save yourself the hassle and buy a new one...
realdan is offline
Old 07-01-2009, 06:08 PM   #3 (permalink)
RMN
yeah the mouse is dying...my old iBall mouse had the same fate.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 07-01-2009, 09:01 PM   #4 (permalink)
Guess what................my mouse is of acer brand!!!
when the hec did they start making mouses?!
well i know no one that uses an acer mouse other than me!!
Well its true.............i didnt have any hope on its performance when i got it itself!
Old 08-01-2009, 09:34 PM   #5 (permalink)
It's true Im not confused
confused!!'s Avatar
I have a microsoft wireless desktop and my mouse is also dying
After the game is over, the pawn and the king go into the same box
confused!! is offline
Download Many links by single click smartygoldenfish Internet & WWW 4 06-04-2008 07:00 AM
take ownership in vista by a single click iMav Software Q&A 5 26-05-2007 01:13 PM
Click problem with Mouse??? go4saket Peripherals 1 16-05-2007 12:43 PM
How to Download the whole Website with a single click??????? Andyiz Internet & WWW 10 14-02-2006 03:59 PM
using 10 search enginne in a single click,is that possible ? arnold QnA (read only) 8 24-02-2005 12:19 AM
- by c4u
