Old 06-01-2009, 07:58 PM   #1 (permalink)
Zen
Zen's Avatar
Default Using LCD Monitor as a TV without the PC
I have a benq 21.5 inch LCD and i want to Use the LCD Monitor as a TV without the PC..
Can it be done with some external TV tuner card or something?, also what would be the requirements of the LCD, DVI or D-Sub (VGA)
Thanks Guys.
-= -= 'beware of the dog, he is very sarcastic' =- =-
Zen is offline
Old 06-01-2009, 08:02 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Using LCD Monitor as a TV without the PC
Buy external tuner card with vga/dvi connector
desiibond is offline
Old 06-01-2009, 09:10 PM   #3 (permalink)
are there any LCD monitors which can play TV (tatasky) directly without needing a tuner or PC.
ranjan2001 is offline
Old 06-01-2009, 09:16 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
There should be some that have RCA ports like Dell 2408WFP. They may play movie without any extra h/w.
http://accessories.us.dell.com/sna/p...9&sku=320-6272
But it's a pretty expensive monitor.
Old 07-01-2009, 11:31 AM   #5 (permalink)
RMN
but aren't there those adapters which convert the normal AV cables to VGA?
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 07-01-2009, 01:52 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I think there are but am not sure about that.
Old 07-01-2009, 06:47 PM   #7 (permalink)
I found this one model from LG which has
Video input & output
Composite & Svideo
But its beyond my budget.
Old 07-01-2009, 10:21 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
dude. seriously, you get a vga tv tuner card for 700 bucsk - 1.5k. You need not pay a premium just for that. Get a good 19" display and get an external tv tuner card.
Old 07-01-2009, 10:37 PM   #9 (permalink)
A VGA tunner works at 680x480 for CRT monitors but for LCD we will need LCD TV tuners @1050x1680 & they are expensive ranging 3500/- upwards.
Old 09-01-2009, 04:22 AM   #10 (permalink)
Point Blanc
and I suppose you mean to say 680x480 is not supported by LCD monitors.
acewin is offline
Old 09-01-2009, 06:44 AM   #11 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Hey buddy i own a techcom LCD TV Tuner & it works upto 1280X1024 res. The good thing is that it isn't expensive & i also play my PS2/X360 games on it without any problems.
keith_j_snyder2 is offline
Old 09-01-2009, 09:45 AM   #12 (permalink)
Its supported but its 4:3 ratio does not do well when on wide screen LCDs which are 16:9 ratio, the image quality looks bad I tested 3-4 of them but none of them looked good. The lcd tuners can remap the images to different ratios I guess that's why they are recommended.
Old 29-03-2009, 09:05 AM   #13 (permalink)
Finally bought Samsung 2233 LCD monitor (Rs 10600/-) which is Full HD in 22 inch, along with Techcom external TV tuner Model SSD 723. (Rs 1350/-)
The 4.3 signal from TATA sky gets adjusted to 16:9 ratio looks bit stretched but the image quality is perfect since this monitor is full HD it gives good reception, on the other hand cable TV signal is too bad & looks awfully bad.
Lg Monitor.... sk8terboi Hardware Q&A 1 16-05-2008 08:33 PM
There is a ghost in my monitor!!!Monitor going crazy!!!!!!need help..... tango_cash Hardware Q&A 1 13-12-2007 12:03 PM
need to buy an lcd monitor CHETHAN N TVs / Monitors 7 23-01-2007 04:01 PM
What about monitor , LAN....? zeus_zz Hardware Q&A 8 04-11-2005 01:50 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
- by c4u
