Old 06-01-2009, 05:18 PM   #1 (permalink)
Default New LCD Monitor
I am going to buy a LCD monitor.
I have these choices:
1. 18.5" from Acer
2. 17" from Samsung
The 17" has better contrast ratio and is a little cheaper.
Which one should I go for?
I currently use a Philips 14" CRT.
akshalok is offline
Old 06-01-2009, 05:21 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: New LCD Monitor
If u have only these 2 choices then go for 2nd choice.(Samsung)
Never go for Acer.
Blogging at:
Technostarry
saqib_khan is offline
Old 06-01-2009, 05:35 PM   #3 (permalink)
Rockstar11's Avatar
Samsung
Zindagi Toofani Hai... Jahan Hai DuckBurg!
Rockstar11 is offline
Old 06-01-2009, 07:52 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
go for 19" display.
the price difference between 17" and 19" is just 1k and the extra real estate is worth the 1k extra.
desiibond is offline
Old 06-01-2009, 08:29 PM   #5 (permalink)
The Sorcerer's Avatar
Model number? Resolution. Helps to check out that way.
Hardware BBQ
The Sorcerer is online now
Old 06-01-2009, 08:34 PM   #6 (permalink)
You gave been GXified
gxsaurav's Avatar
If you can fine Dell 1909W 19" LCD Monitor, then buy it. It is one of the best 19" LCD I have seen.
about.me/gxsaurav
gxsaurav is offline
Old 06-01-2009, 08:35 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
two models i have in mind
Dell 198WFP
Samsung 943nwx
both at 1440x900 resolution.
Old 06-01-2009, 09:06 PM   #8 (permalink)
I need to replace one of my CRT for the kids comp.
Can you suggest me 19" 4:3 or widescreen monitor with multimedia capability so it has speakers & should be able to work with TataSky without needing the computer.
Do I have a choice in what I want?
Price range 9000-12000
ranjan2001 is offline
Old 06-01-2009, 09:15 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I don't think you can find something like that for 19" display.
Old 07-01-2009, 02:25 PM   #10 (permalink)
I don't know for sure number for Acer (it just says:
Acer 18.5" LCD Monitor
Crystalbright with DVI Port)
As for Samsung, the description goes like this:
Samsung 17" LCD Monitor (733NW)
15000:1 Contrast Ratio
I was told the contrast ratio for the acer is 10000:1.
As for other suggestions, suggest me some more please. I hate Dell and Toshiba. Others will work for me. Thanks
akshalok is offline
Old 07-01-2009, 10:32 PM   #11 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hate DELL ?? (heart broken)...
Hate Toshiba ?? (good good)..
Well, u can go in for Samsung, I hv a Samsung 19" LCD (Model: SyncMaster 920 NW) and Samsung isa really good brand in LCDs..so go in for that and u will NOT at all be disappointed (if u jus wanna take a pic b/w Samsung and Acer)..
Btw, Also stay away from ViewSonic :grr...:
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
::::help Help Help My New Monitor:::: ::cyborg:: Hardware Q&A 7 20-08-2008 08:36 PM
New Monitor shankhas Hardware Q&A 8 14-08-2008 06:01 AM
HCL Monitor Most Wanted Hardware Q&A 6 24-07-2008 10:07 AM
There is a ghost in my monitor!!!Monitor going crazy!!!!!!need help..... tango_cash Hardware Q&A 1 13-12-2007 12:03 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
- by c4u
