Old 05-01-2009, 07:54 PM   #1 (permalink)
Default weird problem!
i have been facing a weird problem lately
whenever i take 2-3 renders back to back of some heavy scene under maya, my comp suddenly crashes w/o giving any warning.
i m using a 450w power supply(some local company)
can anyone tell what might b the problem??
"Creativity is all about hiding your sources"
IITian is offline
Old 05-01-2009, 11:50 PM   #2 (permalink)
Default Re: weird problem!
it isnt weird..
your pc cannot handle the heavy processing that takes place and the heat generated can cause the PC to crash/shutdown suddenly
realdan is offline
Old 05-01-2009, 11:59 PM   #3 (permalink)
The Sorcerer's Avatar
Pcs are not supposed to shut down unless made to.
I need temps. Google for real temp and let me know the processor temps on idle first.
Google for orthos and run a blend test for 4-5 hours. Let me know if it shuts down or restarts. If it does, something is wrong. Also update the bios to a newer one. Google for hd tach and run error scan. If you see red square- there are bad sectors. I think asus has a software on their disk to check their rail voltage. Not sure the name but pretty sure its bundled with all newer (and some old) boards.
Hardware BBQ
The Sorcerer is online now
Old 06-01-2009, 07:15 PM   #4 (permalink)
idle temp is 24-25c
orthos ran fine.the peak temp while running orthos was 60c.
hd tach results were also fine..
no such s/w came bundled with my mobo.
any idea what might b the problem??
IITian is offline
Old 08-01-2009, 06:56 PM   #5 (permalink)
do you have a graphics card? i think you might need one
realdan is offline
Old 08-01-2009, 07:27 PM   #6 (permalink)
i've ordered palit 9800gt thru lynx but i think they will take 10days for delivery.
currently i m workin on a project whose deadline is not too far away
so, i didn't want to wait..but this problem has left no other option for me
IITian is offline
Old 09-01-2009, 03:13 PM   #7 (permalink)
direct a "table" fan on your PC to see if the problems occur
realdan is offline
Weird problem ubersoldat Hardware Q&A 2 19-12-2008 04:11 PM
A weird problem fuzzz Software Q&A 1 14-04-2008 01:45 PM
Very Weird Problem naveen_reloaded QnA (read only) 3 08-12-2006 12:40 PM
weird problem krisjr QnA (read only) 6 23-12-2005 06:52 PM
a weird problem.... hearthacker QnA (read only) 11 03-06-2005 08:04 PM
- by c4u
