Old 04-01-2009, 11:04 PM   #1 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Exclamation How is this Config
1)Intel Core2Duo 7300GHz
3)2X1 GB RAM 667 MHz
4)320 GB SATA Seagate or 500GB
5)Any cabby with SMPS
I'm confused about the mobo. I have a budget of 17k max. I'll be adding a GFX card later.
Please suggest a better config if possiible.
I spit Rainbows.
skippednote is offline
Old 05-01-2009, 06:05 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Best CPU for 15K
try to get a Gigabyte G31 chipset based mobo.
hellgate is offline
Old 05-01-2009, 06:15 PM   #3 (permalink)
M3TAL H3AD M3
Is there any other choice as G31 has Shader model 2.0. I have 6k budget for the motherboard.
I spit Rainbows.
Old 06-01-2009, 07:08 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Zotac Has a nvidia 9300/730i based board for around Rs. 5500-6000
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
- by c4u
