Old 04-01-2009, 07:22 PM   #1 (permalink)
Default Please help me in buying a laptop
I want to buy a new laptop within a day or two. I have selected Dell Studio 15 as the laptop of my choice. Is it good, or should I consider any other laptop. Please help. I can spend upto 48,000 on a laptop not more than that. I want a laptop just for some programming, watching movies, and part time blogging..
Please Help
Thank You
http://mobiveda.com
vineetrocks2005 is offline
Old 04-01-2009, 08:37 PM   #2 (permalink)
Default Re: Please help me in buying a laptop
Good choice. The Studio 15 is good enough for all your needs but the integrated 4500MHD graphics won't be enough to decode 1080p video. Upgrade it to the Mobility Radeon HD 3450 if it's within the budget.
drvarunmehta is offline
Old 05-01-2009, 07:47 AM   #3 (permalink)
ok... thanks , anyone else who can help me
http://mobiveda.com
Old 05-01-2009, 09:01 AM   #4 (permalink)
Be cOoL NiGgEr``
marshallz's Avatar
thats a good choice.. check for studio 17 as well.. an ya dell usually has 2-3 config under the same model . so check for the best RAM and AGP congfig under studio 15.
NOTE: WATEVA YOU BUY DONT BUY HP OR COMPAQ LAPTOPS>>> THEY DONT GIVE DRIVERS.!!!
marshallz is offline
Old 05-01-2009, 09:11 AM   #5 (permalink)
Linux all the way
Better go for graphics card instead of bigger screen, if you are going to keep it for many years. Also its better to have a graphics card coz eveybody does watch few movies.
At times life takes a U turn and you get back where you were...
Vishal Patil is offline
Old 05-01-2009, 09:48 AM   #6 (permalink)
At last I am increasing my budget to 52,000 and I am going with this config
<see the screenshot below>
http://img157.imagevenue.com/img.php..._122_960lo.jpg
Now is it alright ?
http://mobiveda.com
Old 05-01-2009, 02:39 PM   #7 (permalink)
Almost perfect. Can you upgrade the screen from 1280x800 to 1440x900 or if the budget allows even 1920x1200?
It might seem like a lot of money for just higher resolution but you'll really enjoy it while watching movies and multitasking with several programs open at once.
Need help in buying a laptop!!!!! tom.vipin Hardware Q&A 1 05-12-2008 01:44 AM
buying laptop dare_devil Laptops and Netbooks 5 08-11-2008 12:45 AM
Buying laptop papai_mcc Hardware Q&A 10 21-06-2007 11:00 PM
Buying a new laptop ashwn_acharya Laptops and Netbooks 21 20-11-2006 03:17 PM
Need help in buying Laptop!! nach p Laptops and Netbooks 1 18-09-2006 03:57 PM
- by c4u
