Hi Guys,
I am planning to buy a new graphics card and am confused between buying a 9800GTx and a HD4850. My requirments are that i should be able to play most(all most all
) games at max resolution and all specs on. Which one is a better buy.
My budget is max Rs 9000.00
MY system build is(non sli mobo)
2GB ram
7300GT(currently)
generic 400watt PSU(suggest a new 500W PSU...budget rs2200 only
Samsung 22" (1650 x 1050) max non DVI
I am planning to buy next week so plz suggest. Beforehand thanks a ton
