Old 02-01-2009, 03:04 AM   #1 (permalink)
swap_too_fast's Avatar
Default CPU overheating
From somedays my PC automatically get restarted without any reason, i was unable to find reason, but then i download intel desktop utility from intel manufractureressite, my cpu is intel core2duo E6550( 2.3 Ghz) , 2 Gb ram.
yesterday I installed unreal tournament 2004 at that time when i started this game, the intel desktop utility which is running in background show me notice that the cpu is overheating (above 69 degree celcius), IS this the reason for which my computer get restarted?
CPU fans rpm is setted to 2000.
should I apply new thermal paste over processor?
There is no second chance.....!!!!
swap_too_fast is offline
Old 02-01-2009, 09:04 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: CPU overheating
Keep the cpu rpm setting to automatic. Clean away any dust on the cpu fans. Did you overclock on those stock heatsinks by any chance? Next time post your system specs including psu.
Hardware BBQ
The Sorcerer is offline
Old 02-01-2009, 09:09 AM   #3 (permalink)
S.I.P.
JojoTheDragon's Avatar
+1 My overheating issue was fixed after that. I did it myself but if you are not used to motherboard fitting then take the help of a comp pro.
Steam: jojothedragon
TDF Steam Group : http://tinyurl.com/3cffox8
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
CPU overheating!! supersaiyan Hardware Q&A 4 27-02-2008 06:06 PM
overheating or something else? fastc0der Hardware Q&A 5 25-09-2007 09:17 PM
cpu overheating The SHARK Hardware Q&A 1 06-03-2007 06:18 PM
Is this Overheating ??? sachin46 Hardware Q&A 1 25-10-2006 12:17 PM
Please help regarding CPU overheating .. kshiraj CPU / Motherboards 5 24-10-2004 01:18 AM
