| Forum |
#1 (permalink) |
#2 (permalink) |
No. Even on a 7.1 channel you can use for a 2.1. In common soundcards like asus and soundblaster front is normally used for 2.1 channel. Just select 2.1 channel in the bundled sound card software and you are set.
Hardware BBQ |
#4 (permalink) |
Depends on which brands and models. I think there is a price list around so check it out. I am using asus xonar dx 7.1 with a temporary altec lansing atp3. You do get soundblaster live value models which are around 1.5k!
Hardware BBQ |
#6 (permalink) |
Bond, Desi Bond!
if the speakers that you have are creative SBS 2.1 then you don't need any dedicated soundcard. The onboard audio should be more than enough.
My first blogspace: http://desiibond.blogspot.com |
#7 (permalink) |
well........when i connect my speakers to the motherboard sound port, only my right speaker and sub woofer works, my left speaker doesnt.
But when i connect the speaker to the front port(headset port) of the cpu, both the speakers works fine.I dont want any wires dangling in front of my cpu.So thought of buying a sound card... |
#8 (permalink) |
There should be a speaker/mic ports on the back of the pc case- always been there. Mind giving us an idea what kinda system you are using
Hardware BBQ |
#9 (permalink) |
yh.....speaker/ mic port at the back has got the problem i think. the speaker works fine when i connect it to the front headphone ports' sound port.
i bought my system in 2005..... its acer aspire v4324 amd athlon 64 processor 3200+ 1GB DDR RAM 160GB hard drive nvidia 256MB graphics card Last edited by super jango; 02-01-2009 at 03:35 PM. Reason: Automerged Doublepost |
#10 (permalink) |
so u can use only a 2.1
if u want to use a 5.1 u need to use a jack splitter to split your one output but i dont know if it will give the surround effect or just play the same sound in front and back speakers |
#11 (permalink) |
well.........i got one intex sound card from a store to try out.......fixed it and installed the drivers..........but only my left speaker and woofer works now!earlier it was the right speaker that wasnt working...........could it be the problem with the speakers then?my speakers are kept close to my CRT monitor and i've heard from someone that you shouldnt keep it close as some magnetic interferences may occur.............could it be the problem?!
#12 (permalink) |
Dont know about the speakers you have but desktop speakers are magnetically shielded and they are supposed to be(atleast the ones I know off). If you have a tv- you can always plug your speakers on the headphone jack and see if the right speakers are working.
Hardware BBQ |
#13 (permalink) |
well..........it works now!!! first the speakers were connected to the green cloured porton the sound card.......i tried connecting it in a black port near it and both strted working fine!!no problems anymore!!
#14 (permalink) |
Good
Hardware BBQ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| can a cheep sound card improve sound quality? | gau_pppu | QnA (read only) | 7 | 26-09-2008 12:56 PM |
| Hissing Sound/Disturbance Coming From Speakers/Sound Card ! | mikeon | Audio | 8 | 15-10-2006 10:37 AM |
| Ubuntu 5.10 creative vibra128 sound card -no sound | smurthygr | Open Source | 8 | 25-01-2006 11:59 PM |
