| Forum |
#1 (permalink) |
I have been observing that my CPU is now getting hotter than what it would be in the past. I am wondering what would be causing it as I have not made any changes in my system H/W or S/W or the processing load/duration etc for past several months, plus this is winter time now. The hardware utility or BIOS shows around 40 Deg C but I am skeptical about it. The heat is mildly felt even if I open the cabinet door. This was not the case before. My config… it’s quite old but has worked well for past 4 years! AMD Athlon XP 2000, Biostar M7NCG 400, 512 MB, 300 W SMPS, NVidia 6200 AGP card, 80 GB HDD, one DVD RW, XP SP2, one additional fan in the cabinet. All fans CPU, Cabinet + SMPS are operational. The only change I notice is that CPU fan is now making more noise that before. This is old system and as such there's no facility to control / vary fan speed based on CPU temperature The auto restart issue is only noticed after 2 – 3 hours of continuous operation. Hence for the time being I am assuming it could be due to CPU or such heating. Any suggestions would be great. Thx. |
#2 (permalink) |
Most probably the thermal paste on the processor has lost its thermal properties.
Hardware BBQ |
#4 (permalink) |
also check the heatsink and see if it is clogged with dust and dirt..also check if the fan is spinning fast enough..you could also try oiling it or get a new one..
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va |
#5 (permalink) |
You get thermal paste in any pc shop. They cost as low as 20-30 bucks to good quality thermal paste like artic mx-2 for 300 bucks. Make you put it as little as you can- but not that little. The chips inside the proccy is exposed unlike the ones we get now so follow the instructions here:
http://www.arcticsilver.com/pdf/appi...core_expsd.pdf
Hardware BBQ |
#6 (permalink) |
Thanks for your help and advice..so I decided to clean my PC today and I could notice unimaginable amount of dust accumulation on the CPU heatsink. Though I have cleaned my PC several times…so far I never touched the heatsink…This time I removed the fan on top of it to clean it from inside and see the attached picture..this is what the heatsink fins were holding in it after 4 years!!
The next pic is after cleaning the fins!! Last edited by patkim; 01-01-2009 at 08:13 PM. |
#7 (permalink) |
Ahh good. Did you check the temps after cleaning the fans. If it improved drastically then you dont need to change thermal paste.
Hardware BBQ |
#8 (permalink) |
As such the temp is still around 40 Deg C but I guess the heat dissipation should now be relatively better after removing heap of dust from the heatsink.
Will now keep it to test for a few days and see if there are any more restarts. Thanks |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| PC Restarts | sachinc | Hardware Q&A | 12 | 23-01-2008 09:20 PM |
| Restarts | joekachy | Gamerz | 3 | 28-07-2007 01:00 AM |
| Restarts every now and then | aneesh kalra | Hardware Q&A | 4 | 09-02-2007 09:02 AM |
| Pc restarts | navisangha | Software Q&A | 3 | 24-12-2006 04:12 PM |
| pc restarts itself | niraj_dixit | Hardware Q&A | 5 | 24-05-2006 10:56 PM |
